I have an ESPHome connected with inputs for hot water and heating zone demands. I have an output for the boiler “demand signal”.
The 3 input pins increment a number by 1,2,4 when pressed.
#HW Demand Input
binary_sensor:
- platform: gpio
device_class: heat
pin:
number: 14
inverted: true
mode:
input: true
pullup: true
filters:
- delayed_on_off: 100ms
on_press:
#1st bit in state table
then:
- number.set:
value: !lambda 'return id(InputState).state + 1;'
on_release:
then:
- number.set:
value: !lambda 'return id(InputState).state - 1;'
#CH1 Demand input
- platform: gpio
device_class: heat
pin:
number: 12
inverted: true
mode:
input: true
pullup: true
filters:
on_press:
#2nd bit in state table
then:
- number.set:
value: !lambda 'return id(InputState).state + 2;'
on_release:
then:
- number.set:
value: !lambda 'return id(InputState).state - 2;'
#CH2 Demand input
- platform: gpio
device_class: heat
pin:
number: 13
inverted: true
mode:
input: true
pullup: true
filters:
on_press:
#3rd bit in state table
then:
- number.set:
value: !lambda 'return id(InputState).state + 4;'
on_release:
then:
- number.set:
value: !lambda 'return id(InputState).state - 4;'
These inputs are effectively creating a state table, which I then test within the “InputState” number definition to switch 2 outputs - one to fire the boiler, one to set a PWM output which controls the boiler flow temperature via a digital potentiometer.
number:
min_value: 0
max_value: 32
step: 1
restore_value: true
optimistic: true
on_value:
#switch boiler demand on for whichever states need it if any inputs are high. Off if not
- if:
condition:
or:
- and:
- lambda: 'return x >= 1;'
- lambda: 'return x <= 15;'
- lambda: 'return x == 18;'
- lambda: 'return x == 20;'
- lambda: 'return x == 22;'
- lambda: 'return x == 24;'
- lambda: 'return x == 26;'
- lambda: 'return x == 28;'
- lambda: 'return x == 30;'
then:
switch.turn_on: Boiler_Demand
else:
switch.turn_off: Boiler_Demand
#set boiler flow temp hot when we're heating the cylinder and set away mode
- if:
condition:
or:
- lambda: 'return x == 1;'
- lambda: 'return x == 8;'
- lambda: 'return x == 9;'
then:
light.turn_on:
brightness: !lambda |-
return id(Boiler_High_Temp).state / 100.0;
else:
light.turn_on:
return id(Boiler_Low_Temp).state / 100.0;
This all works fine, apart from on 1st boot.
If the inputs are “on” during boot, then the “on_press” of the inputs does not appear to fire and “InputState” remains as 0. If I then switch the input “off” and back on again then the on_release and on_press events are registered.
Not quite sure where the problem is? Is it becase “InputState” has not been initialised when the input is evaluated?
Any ideas on how to resolve? Cheers.
