On restart all automations except 1 are disabled?
This just started happening within the last few updates. When I restart HassIO or reboot, all my automations except one start in the disabled state.
Config checks out ok. I don’t see anything in the logs.
Any ideas?
I see one similar post:
but no responses…
Do you have
initial_state: 'on'
For all your automations?
Well. Don’t I feel stupid.
initial_state: True
was in only the one that was starting out on. But, something must have changed, as they used to start out on by default before.
I added the above to each automation, and all good now.
Thanks.
The ‘default’ behaviour is that it remembers its previous state over restart. However if there’s a database error during the restart process it can’t, so defaults to off. Setting initial: ensures that it is always on.
Hope this helps.
In that case, maybe I have a db error…
How do I check for db error and/or run repair?
Thanks…
It’s more if when you’ve restarted it didn’t finish writing to the database than a proper error. If there’s nothing in your logs about failure of the database it’s fine.
I sometimes get ‘found unfinished session’ which is directly linked to when I restart and the service ends up being killed by systemctl. Those are the times when it won’t ‘remember’ automation states and a few other things.
