my homeAssistant is running for a long time on a Debian12 fine.
Now for some reason my Grafana and InfluxDB AddOns are not seen on the GUI any more. I rebooted the host but no change.
I can connect with the Hassio-App to the GUI and see automations and all this. Going to the Add-On part it shows me an error and recommends to read logs.
So I did and as far as I can see the InfluxDB Kapacitor has issues.
Jan 24 09:35:53 hoas addon_a0d7b954_influxdb[648]: [09:35:53] INFO: Kapacitor is waiting until InfluxDB is available...
Jan 24 09:35:53 hoas addon_a0d7b954_influxdb[648]: jq: error (at <stdin>:1): null (null) has no keys
Jan 24 09:35:53 hoas addon_a0d7b954_influxdb[648]: [09:35:53] INFO: Starting the InfluxDB...
Jan 24 09:36:08 hoas addon_a0d7b954_influxdb[648]: 2024/01/24 09:36:08 Using configuration at: /etc/kapacitor/kapacitor.conf
Jan 24 09:36:08 hoas addon_a0d7b954_influxdb[648]: ts=2024-01-24T09:36:08.357+01:00 lvl=error msg="encountered error" service=run err="parse config: Near line 22 (last key
parsed 'reporting.enabled'): expected value but found '<' instead"
Jan 24 09:36:08 hoas addon_a0d7b954_influxdb[648]: run: parse config: Near line 22 (last key parsed 'reporting.enabled'): expected value but found '<' instead
Jan 24 09:36:08 hoas addon_a0d7b954_influxdb[648]: [09:36:08] WARNING: Kapacitor crashed, halting add-on
So there seems to be a problem in the file /etc/kapacitor.conf in line 22.
I can not find the file on my Debian system, I assume it is in one of the Docker containers. So I did a find /var/lib/docker -name kapacitor.conf
and found several instances of it, althought the docker paths change from one minute to the next.
However, I managed to find a file where line 22 in section [reporting] seems to match:
[reporting]
enabled = <no value>
url = "https://usage.influxdata.com"
So I edited the file and set the line 22 to enabled = "true"
and rebooted.
But it looks like the file is generated dynamically as it disappears and get re-created.
So what switch do I have to tell to create a valid kapacitor.conf file?
Thanks!
/KNEBB
