"on_value_range" definition of "above" and "below"
This might be a stupid question, but what is the exact definition of “above” and “below” of “on_value_range”?
For example, let’s assume we have a pulse_counter:
  • platform: pulse_counter
    pin: GPIO17
    on_value_range:
    - below: 2
    then:
    - above: 2
    below: 10
    then:
    - above: 10
    then:
As you can see, i want to classify those values into three groups:
x < 2
2 <= x < 10
10 <= x
So, back to the initial question:
  • does below: 2 mean x <= 2 or x < 2?
  • What is triggered on value = 2
Edit: Shall i use below: 1.9 e.g. ?
Please use code blocks to format your pasted code, not the quote option.
But “below” means less than. Not less than or equal to.
x < 2
below: 2
2 <= x < 10
above: 1.99
below: 10
10 <= x
above: 9.99
Alternatively if you use lambdas you can use <, <=, >, and >= which may be more easily understood.
