With this automation I would like, if
- Garage open -> light is red
- garage closed -> light green
- Garage unknown -> yellow.
In the logs I always get the error:
Logger: homeassistant.components.automation.alarm_garagentor
Source: core.py:1289
Integration: Automatisierung (documentation, issues)
First occurred: 13:01:12 (1 occurrences)
Last logged: 13:01:12
While executing automation automation.alarm_garagentor
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 426, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 985, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 239, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 247, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 454, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1289, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec
v = func(v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 338, in _exec
v = func(path, v)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: None for dictionary value @ data['xy_color']
- id: '1602449066927'
alias: Alarm Garagentor
description: ''
- platform: state
entity_id: sensor.garage_modtm_door_state
condition: []
- service: light.turn_on
data_template:
xy_color: >-
{% if is_state('sensor.garage_modtm_door_state', 'unknown') %}
[0.16,0.504]
{% elif is_state('sensor.garage_modtm_door_state', 'closed') %}
[0.16,0.504]
{% elif is_state('sensor.garage_modtm_door_state', 'open') %}
[0.16,0.504]
{% endif %}
entity_id: light.0x00158d0003912bec_light
- delay: 00:00:10
- service: light.turn_off
data: {}
mode: restart
