One button cycles through lights
Is there a way to cycle through lights with only one button?
I have a Xiaomi button and 2 bulbs. What I would like to do is:
First button click: light 1 goes on
Second button click: light 2 also goes on, light 1 stays on
Third button click: both lights go off
Is this even possible? Regardless of button/light type?
Thanks,
FC
You can do that with automations. I think the easiest might be to create an input_select and have the button advance through the select’s options. Build automations tgriggering on the state of the input_select. Or you could have one automation that watches the input_select for state changes and use service_template to run a script/scene of your choice based on the input_select’s state.
Tanks, gotta digest this, since I am a beginner on home assistant :slight_smile:
But I’ll figure it out …
Until then if anyone has maybe examples of similar stuff, please post it.
This looks like a good place to start:
Get the lights to change based on your input select first. Once that works, add the automation to cycle through states based on clicks of your button.
Thanks, looks like exactly what I need, I will do that!
