One DS18B20 sensor not shows in HA
I have 4 ds18B20 sensors attached to my board. 3 shows in Ha but one doesn’t see.
MY esp code:
esphome:
  platform: ESP32
  board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "u9rxA1MvgMGcsVmHpKIAllouRop1d3GpyCwx1AuO+AQ="
ota:
  password: "9f274038fdd58af658c1552a34a24c13"
web_server:
  port: 80
#wifi:
#  ssid: !secret wifi_ssid
#  password: !secret wifi_password
#  ap:
#    ssid: "Kc868-A8 Fallback Hotspot"
#    password: "bhSSvT9Gsa0v"
#captive_portal:
# Example configuration entry for ESP32
i2c:
  sda: 4
  scl: 5
  scan: true
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
# Optional manual IP
#manual_ip:
#static_ip: 192.168.1.199
#gateway: 192.168.1.1
#subnet: 255.255.255.0
pcf8574:
  - id: 'pcf8574_hub_out_1' # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_in_1' # for input channel 9-16
    address: 0x22
dallas:
  - pin: GPIO14
cover:
  - platform: time_based
    open_action:
      - switch.turn_on: futes_out3
    open_duration: 125sec
    close_action:
      - switch.turn_on: futes_out4
    close_duration: 125sec
    stop_action:
      - switch.turn_off: futes_out3
      - switch.turn_off: futes_out4
    open_action:
      - switch.turn_on: futes_out1
    close_action:
      - switch.turn_on: futes_out2
    stop_action:
      - switch.turn_off: futes_out1
      - switch.turn_off: futes_out2
# Individual outputs
switch:
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub_out_1
      number: 0
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 1
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 2
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 3
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 4
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 5
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 6
      mode: OUTPUT
    inverted: true
  - platform: gpio
    pin:
      number: 7
      mode: OUTPUT
    inverted: true
binary_sensor:
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub_in_1
      number: 0
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 1
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 2
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 3
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 4
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 5
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 6
      mode: INPUT
      inverted: true
  - platform: gpio
    pin:
      number: 7
      mode: INPUT
      inverted: true
  - platform: dallas
    address: 0x69030494972f9328
    name: "Fűtés előre menő_id1"
  - platform: dallas
    address: 0xd203129497296d28
    name: "Hűtés előre menő_id3"
  - platform: dallas
    address: 0x3b3c01e0762ef628
    name: "Hűtés vissztérő_id4"
  - platform: dallas
    address: 0x7603129497519a28
  - platform: homeassistant
    entity_id: sensor.nsnappali_temperature
climate:
#PÕRANDAKLIIMA
  - platform: thermostat
    name: Fűtés keverő vezérlés
    icon: mdi:heater
    visual:
      min_temperature: 20 °C
      max_temperature: 50 °C
      temperature_step: 0.1 °C
    min_idle_time: 1s
    min_heating_run_time: 1s
    min_cooling_run_time: 1s
    min_heating_off_time: 1s
    min_cooling_off_time: 1s
    set_point_minimum_differential: 1
    heat_overrun: 0.0
    heat_deadband: 0.0
    cool_overrun: 0.0
    cool_deadband: 0.0
    sensor: futes_elore
    heat_action:
      - script.execute: futes_kervero_nyit
    cool_action:
      - script.execute: futes_kevero_zar
    idle_action:
      - script.stop: futes_kervero_nyit
      - script.stop: futes_kevero_zar
    preset:
      - name: küte
        default_target_temperature_low: 20 °C
        default_target_temperature_high: 45 °C
    name: Hűtés keverő vezérlés
    icon: mdi:heater
    visual:
    min_idle_time: 1s
    heat_overrun: 0.0
    heat_deadband: 0.0
    cool_overrun: 0.0
    cool_deadband: 0.0
    sensor: hutes_elore
    heat_action:
      - script.execute: hutes_kervero_nyit
    cool_action:
      - script.execute: hutes_kevero_zar
    idle_action:
      - script.stop: hutes_kervero_nyit
      - script.stop: hutes_kevero_zar
    preset:
      - name: küte
    name: Nappali termosztát
    icon: mdi:heater
    visual:
      max_temperature: 30 °C
      temperature_step: 0.2 °C
    min_idle_time: 1s
    min_heating_run_time: 10min
    min_cooling_run_time: 10min
    min_heating_off_time: 5min
    min_cooling_off_time: 5min
    set_point_minimum_differential: 0.2
    heat_overrun: 0.0
    heat_deadband: 0.0
    cool_overrun: 0.0
    cool_deadband: 0.0
    sensor: nappali_temp
    heat_action:
      - switch.turn_on: futes_out5
    cool_action:
    idle_action:
      - switch.turn_off: futes_out5
script:
#PÕRANDA3T
  - id: futes_kervero_nyit
    then:
    - repeat:
        count: 100
        then:
          - delay: 1s
          - delay: 35s
  - id: futes_kevero_zar
    then:
    - repeat:
        count: 100
        then:
          - delay: 1s
          - delay: 35s
#PÕRANDA3T
  - id: hutes_kervero_nyit
    then:
    - repeat:
        count: 100
        then:
          - delay: 1s
          - delay: 35s
  - id: hutes_kevero_zar
    then:
    - repeat:
        count: 100
        then:
          - delay: 1s
          - delay: 35s
Is the address correct?
Show the serial log for the 1-wire bus scan.
Also GPIO14 is not a good choice. It outputs PWM at boot and could confuse your sensors. See the table lower down on this page for the best GPIOs to use: https://randomnerdtutorials.com/esp32-pinout-reference-gpios/
Yes, the address is ok. i can see the sensor data on the webpage of the device. it only not shows in HA.
Please show your device serial logs.
Oh I miss configured it. That DS sensor ID was declaired in an other esphome device config so HA missed it.
Thanks for your replies
