I have one ESPhome device (ESP32 based) that since the last two versions of ESPhome updates refuses to update. All my other devices update just fine.
I’ve tried cleaning build files to no avail. An identical device updates just fine - it’s isolated just to this one. I have no idea what to do next
I can clearly see in the log output from the install/update that it’s not using the latest installed ESPHome version (2024.3.1) for whatever reason it is flashing 2024.3.0 to this device which I assume is why it still thinks it needs to be updated:
INFO ESPHome 2024.3.1
INFO Reading configuration /config/esphome/bedroomtvquad.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing bedroomtvquad (board: mhetesp32devkit; framework: espidf; platform: platformio/[email protected])
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.5
INFO Installing bblanchon/ArduinoJson @ 6.18.5
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40406.240122 (4.4.6)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Generating assembly for certificate bundle...
Dependency Graph
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
Linking .pioenvs/bedroomtvquad/firmware.elf
RAM: [== ] 16.9% (used 55220 bytes from 327680 bytes)
Flash: [======= ] 73.9% (used 1356409 bytes from 1835008 bytes)
Building .pioenvs/bedroomtvquad/firmware.bin
Creating esp32 image...
Successfully created esp32 image.
esp32_create_combined_bin([".pioenvs/bedroomtvquad/firmware.bin"], [".pioenvs/bedroomtvquad/firmware.elf"])
Wrote 0x15cb10 bytes to file /data/build/bedroomtvquad/.pioenvs/bedroomtvquad/firmware-factory.bin, ready to flash to offset 0x0
========================= [SUCCESS] Took 64.44 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 10.10.150.53
INFO Uploading /data/build/bedroomtvquad/.pioenvs/bedroomtvquad/firmware.bin (1362704 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 18.83 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 10.10.150.53 using esphome API
INFO Successfully connected to bedroomtvquad @ 10.10.150.53 in 11.336s
INFO Successful handshake with bedroomtvquad @ 10.10.150.53 in 0.122s
[13:11:48][I][app:102]: ESPHome version 2024.3.0 compiled on Mar 21 2024, 12:46:52
