Hello guys, is it possible to have one integration with more entities?
In particular, I’m trying to figure out how to have a gpslogger integration for my phone (already configured) and my girlfriend’s one.
On the UI integrations page I cannot find a button ‘+’ or anything like that to add a new entity…
Thanks!
If you go to “Developer Tools -> Configuration -> Integrations” there should be a “+” button on the bottom, right corner, do you see GPS Logger there?
Yes I can see it…but I cannot add more than one gpslogger instance from it…
You don’t need more than one GPSLogger instance. When you configure GPSLogger, you define the device name in the body.
I have 5 devices on my GPSLogger instance, all with different device names
Ah I understand now, read the GPS Logger docs. You only need one GPS Logger integration, you just need to setup GPS Logger on your girlfriend’s phone and then it will appear under this integration.
Yes but I need to monitor two devices with gpslogger…How can I add the second device to the HA integration?
The same way you integrated your phone. Install the GPS Logger app etc. as written in the docs.
You just add the device like you did with yours. The URL is not specific to YOUR device.
Ok, so I can use the same webhook for as many devices as I need?
Yes. As many devices as you want to track. In the body of the connection, you can specify the name of the device.
