I have three lights that are configured in configuration.yaml instead of the Tasmota integration because of the way they work (was true back then). They are three way switches that uses rules and a virtual button to simulate the three way. Since the upgrade of either HA or Tasmota (they were at 8.5.2 and were upgraded to 12.2), it triggers errors in the homeassistant.log at startup.
This is how they are configured in configuration.yaml
mqtt:
light:
- name: "LumiereGarage"
state_topic: "stat/LumiereGarage/POWER1"
command_topic: "cmnd/LumiereGarage/EVENT"
availability_topic: "tele/LumiereGarage/LWT"
qos: 0
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
unique_id: 500291B18117
This is what shows up in the homeassistant.log at startup.
2022-12-07 10:41:42.151 ERROR (MainThread) [homeassistant.util.logging] Exception in discovery_message_received when handling msg on 'tasmota/discovery/500291B18117/config': '{"ip":"192.168.2.176","dn":"LumiereGarage","fn":["LumiereGarage","LumiereGarage2",null,null,null,null,null,null],"hn":"LumiereGarage-0279","mac":"500291B18117","md":"Generic","ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"8.5.1","t":"LumiereGarage","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,1,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1],"btn":[0,0,0,0],"so":{"11":0,"13":1,"17":0,"20":0,"30":0,"68":0,"73":0,"80":0},"lk":1,"lt_st":0,"ver":1}'
File "/usr/local/lib/python3.10/site-packages/hatasmota/discovery.py", line 213, in discovery_message_received
payload = TasmotaDiscoveryMsg(json.loads(_payload))
File "/usr/local/lib/python3.10/site-packages/hatasmota/discovery.py", line 163, in __init__
config = TASMOTA_DISCOVERY_SCHEMA(config)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: required key not provided @ data['so']['82']
From what I gather, ‘so’ here stands for SetOption and I’m puzzled why it needs to get SetOption82 which is “Reduce the CT range from 153..500
to 200..380
to accommodate with Alexa range”.
How can I stop there errors? Might be OCD from my part but I like to see my log clean
Thanks again
