Hello guys,
I just finished to setup my new Dashboard, so i’m gonna share this project with the community =D
You can find all the info here: NdR TabletUI Repo
Of course, any suggestion is appreciated!
Hello guys,
Small Update!
Updated the code to be compatible with Layout Card 2.2.1
- type: 'custom:mini-graph-card'
layout:
grid-area: graph
To:
view_layout:
grid-area: graph
Nice UI, I will take a look into it.
Just wanted to give you my compliments. Looks good, not using it myself because I designed my own dash. But well done
is this still alive? downloaded everything and the no-header trick does not appear to be working for me…what could I have missed?
Sure, probably something was changed. Today night I will give it a look!
nevermind…I figured that out it was an error on my part!
@NdR On another note…I’m trying to implement popups but they popup very small for some reason…only difference I can see is that you put each popup in a separate yaml where mine are right at the top of all views in raw configuration…any ideas?
Hi guys,
I would like to use this interface which I find beautiful, thanks to andrea
@NdR, but impossible to resize .
Have I forgotten something in the configuration?
thank you
Hey, great dashboard!
I also use a floor plan, but I didn’t know it was possible to add icons to switch the lights on and off. 🤩
Is there a YouTube video where I can see how it works? Or maybe a blog or another resource I can check out?
