morning all.
so i have a nodemcu with temp/humidity sensors and self battery level.
as its battery powered im using mqtt instead of the api.
the temp and humidty work fine and keep the last known values in sensor entity
the battery level however reverts to unavailable
the nodemcu yaml is as follows
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
#api:
ota:
password: !secret ota_password
wifi:
power_save_mode: HIGH
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.1.115
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Nmcu2 Fallback Hotspot"
password: !secret fallbackappassword
web_server:
port: 80
auth:
username: admin
password: !secret webservpass
captive_portal:
deep_sleep:
run_duration: 4s
sleep_duration: 15min
mqtt:
broker: 192.168.1.117
username: !secret mqtt_username
password: !secret mqtt_password
birth_message:
topic: nodemcuv2/status
payload: ''
retain: true
will_message:
payload: ''
retain: true
on_message:
- topic: deep_sleep/ota_mode
payload: 'ON'
then:
- deep_sleep.prevent: battery_deep_sleep
payload: 'OFF'
then:
- mqtt.publish:
payload: 'PASS'
qos: 2
retain: true
- deep_sleep.enter: battery_deep_sleep
- platform: wifi_signal
update_interval: 1s
- platform: dht
pin: D7
temperature:
name: "nodemcutwo Temperature"
humidity:
name: "nodemcutwo Humidity"
update_interval: 1s
- platform: adc
pin: A0
retain: true
update_interval: 1s
expire_after: 1860s
device_class: battery
unit_of_measurement: "%"
accuracy_decimals: 1
filters:
- multiply: 7.959902632416832
- calibrate_linear:
- 8.4 -> 100
- 2.8 -> 0
text_sensor:
- platform: wifi_info
ip_address:
name: nodemcutwo IP Address
ssid:
name: nodemcutwo Connected SSID
bssid:
name: nodemcutwo Connected BSSID
mac_address:
name: nodemcutwo Mac Wifi Address
scan_results:
name: nodemcutwo Latest Scan Results
and here is a log of it waking up and transmitting
INFO Reading configuration /config/esphome/nodemcutwo.yaml...
INFO Starting log output from nodemcutwo/debug
INFO Connected to MQTT broker!
[12:33:01][I][deep_sleep:103]: Beginning Deep Sleep
[12:38:59][I][mqtt:215]: MQTT Connected!
[12:39:00][C][deep_sleep:035]: Setting up Deep Sleep...
[12:39:00][I][deep_sleep:040]: Scheduling Deep Sleep to start in 4000 ms
[12:39:00][I][app:062]: setup() finished successfully!
[12:39:00][D][text_sensor:067]: 'nodemcutwo Connected SSID': Sending state 'WiFi-5F80'
[12:39:00][D][sensor:124]: 'nodemcutwo ssi': Sending state -44.00000 dBm with 0 decimals of accuracy
[12:39:00][D][text_sensor:067]: 'nodemcutwo Connected BSSID': Sending state '34:E8:94:7B:5F:80'
[12:39:00][D][sensor:124]: 'nodemcutwo Battery': Sending state 28.01105 % with 1 decimals of accuracy
[12:39:00][D][text_sensor:067]: 'nodemcutwo IP Address': Sending state '192.168.1.115'
[12:39:00][I][app:102]: ESPHome version 2022.2.1 compiled on Feb 19 2022, 00:44:25
[12:39:00][C][wifi:491]: WiFi:
[12:39:00][C][wifi:353]: Local MAC: 40:91:51:50:B6:88
[12:39:00][C][wifi:354]: SSID: 'WiFi-5F80'[redacted]
[12:39:00][C][wifi:355]: IP Address: 192.168.1.115
[12:39:00][C][wifi:356]: BSSID: 34:E8:94:7B:5F:80[redacted]
[12:39:00][C][wifi:358]: Hostname: 'nodemcutwo'
[12:39:00][C][wifi:360]: Signal strength: -44 dB ▂▄▆█
[12:39:00][C][wifi:364]: Channel: 10
[12:39:00][C][wifi:365]: Subnet: 255.255.255.0
[12:39:00][C][wifi:366]: Gateway: 192.168.1.1
[12:39:00][C][wifi:367]: DNS1: 0.0.0.0
[12:39:00][C][wifi:368]: DNS2: 0.0.0.0
[12:39:00][C][logger:233]: Logger:
[12:39:00][C][logger:234]: Level: DEBUG
[12:39:00][C][logger:235]: Log Baud Rate: 115200
[12:39:00][C][logger:236]: Hardware UART: UART0
[12:39:00][C][dht:017]: DHT:
[12:39:00][C][dht:018]: Pin: GPIO13
[12:39:00][C][dht:020]: Auto-detected model: DHT11
[12:39:00][C][dht:027]: Update Interval: 1.0s
[12:39:00][C][dht:029]: Temperature 'nodemcutwo Temperature'
[12:39:00][C][dht:029]: Device Class: 'temperature'
[12:39:00][C][dht:029]: State Class: 'measurement'
[12:39:00][C][dht:029]: Unit of Measurement: '°C'
[12:39:00][C][dht:029]: Accuracy Decimals: 1
[12:39:00][C][dht:030]: Humidity 'nodemcutwo Humidity'
[12:39:00][C][dht:030]: Device Class: 'humidity'
[12:39:00][C][dht:030]: State Class: 'measurement'
[12:39:00][C][dht:030]: Unit of Measurement: '%'
[12:39:00][C][dht:030]: Accuracy Decimals: 0
[12:39:00][C][adc:062]: ADC Sensor 'nodemcutwo Battery'
[12:39:00][C][adc:062]: Device Class: 'battery'
[12:39:00][C][adc:062]: State Class: 'measurement'
[12:39:00][C][adc:062]: Unit of Measurement: '%'
[12:39:00][C][adc:062]: Accuracy Decimals: 1
[12:39:00][C][adc:067]: Pin: GPIO17
[12:39:00][C][adc:094]: Update Interval: 1.0s
[12:39:00][C][wifi_info:013]: WifiInfo Mac Address 'nodemcutwo Mac Wifi Address'
[12:39:00][C][captive_portal:144]: Captive Portal:
[12:39:00][C][web_server:179]: Web Server:
[12:39:00][C][web_server:180]: Address: 192.168.1.115:80
[12:39:00][C][mdns:084]: mDNS:
[12:39:00][C][mdns:085]: Hostname: nodemcutwo
[12:39:00][C][ota:085]: Over-The-Air Updates:
[12:39:00][C][ota:086]: Address: 192.168.1.115:8266
[12:39:00][C][ota:089]: Using Password.
[12:39:00][C][mqtt:064]: MQTT:
[12:39:00][C][mqtt:065]: Server Address: 192.168.1.117:1883 (192.168.1.117)
[12:39:00][C][mqtt:067]: Username: 'mqtt3'[redacted]
[12:39:00][C][mqtt:068]: Client ID: 'nodemcutwo-40915150b688'[redacted]
[12:39:00][C][mqtt:070]: Discovery prefix: 'homeassistant'
[12:39:00][C][mqtt:071]: Discovery retain: YES
[12:39:00][C][mqtt:073]: Topic Prefix: 'nodemcutwo'
[12:39:00][C][mqtt:075]: Log Topic: 'nodemcutwo/debug'
[12:39:00][C][mqtt:078]: Availability: 'nodemcuv2/status'
[12:39:00][C][wifi_signal.sensor:009]: WiFi Signal 'nodemcutwo ssi'
[12:39:00][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[12:39:00][C][wifi_signal.sensor:009]: State Class: 'measurement'
[12:39:00][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[12:39:00][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[12:39:00][C][wifi_info:009]: WifiInfo IPAddress 'nodemcutwo IP Address'
[12:39:00][C][wifi_info:011]: WifiInfo SSID 'nodemcutwo Connected SSID'
[12:39:00][C][wifi_info:012]: WifiInfo BSSID 'nodemcutwo Connected BSSID'
[12:39:00][W][dht:169]: Requesting data from DHT failed!
[12:39:00][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[12:39:00][D][sensor:124]: 'nodemcutwo Temperature': Sending state nan °C with 1 decimals of accuracy
[12:39:00][D][sensor:124]: 'nodemcutwo Humidity': Sending state nan % with 0 decimals of accuracy
[12:39:00][C][wifi_info:010]: WifiInfo Scan Results 'nodemcutwo Latest Scan Results'
[12:39:00][C][mqtt:590]: MQTT Message Trigger:
[12:39:00][C][mqtt:591]: Topic: 'deep_sleep/ota_mode'
[12:39:00][C][mqtt:592]: QoS: 0
[12:39:00][C][mqtt.sensor:027]: MQTT Sensor 'nodemcutwo ssi':
[12:39:00][C][mqtt.sensor:031]: State Topic: 'nodemcutwo/sensor/nodemcutwo_ssi/state'
[12:39:00][C][mqtt.sensor:027]: MQTT Sensor 'nodemcutwo Temperature':
[12:39:00][C][mqtt.sensor:031]: State Topic: 'nodemcutwo/sensor/nodemcutwo_temperature/state'
[12:39:00][C][mqtt.sensor:027]: MQTT Sensor 'nodemcutwo Humidity':
[12:39:00][C][mqtt.sensor:031]: State Topic: 'nodemcutwo/sensor/nodemcutwo_humidity/state'
[12:39:00][C][mqtt.sensor:027]: MQTT Sensor 'nodemcutwo Battery':
[12:39:00][C][mqtt.sensor:029]: Expire After: 1860s
[12:39:00][C][mqtt.sensor:031]: State Topic: 'nodemcutwo/sensor/nodemcutwo_battery/state'
[12:39:00][C][mqtt.text_sensor:023]: MQTT Text Sensor 'nodemcutwo IP Address':
[12:39:00][C][mqtt.text_sensor:024]: State Topic: 'nodemcutwo/sensor/nodemcutwo_ip_address/state'
[12:39:00][C][mqtt.text_sensor:023]: MQTT Text Sensor 'nodemcutwo Connected SSID':
[12:39:00][C][mqtt.text_sensor:024]: State Topic: 'nodemcutwo/sensor/nodemcutwo_connected_ssid/state'
[12:39:00][C][mqtt.text_sensor:023]: MQTT Text Sensor 'nodemcutwo Connected BSSID':
[12:39:00][C][mqtt.text_sensor:024]: State Topic: 'nodemcutwo/sensor/nodemcutwo_connected_bssid/state'
[12:39:00][C][mqtt.text_sensor:023]: MQTT Text Sensor 'nodemcutwo Mac Wifi Address':
[12:39:00][C][mqtt.text_sensor:024]: State Topic: 'nodemcutwo/sensor/nodemcutwo_mac_wifi_address/state'
[12:39:00][D][sensor:124]: 'nodemcutwo ssi': Sending state -43.00000 dBm with 0 decimals of accuracy
[12:39:00][C][mqtt.text_sensor:023]: MQTT Text Sensor 'nodemcutwo Latest Scan Results':
[12:39:01][C][mqtt.text_sensor:024]: State Topic: 'nodemcutwo/sensor/nodemcutwo_latest_scan_results/state'
[12:39:01][C][deep_sleep:047]: Setting up Deep Sleep...
[12:39:01][C][deep_sleep:050]: Sleep Duration: 900000 ms
[12:39:01][C][deep_sleep:053]: Run Duration: 4000 ms
[12:39:01][D][sensor:124]: 'nodemcutwo Battery': Sending state 28.01105 % with 1 decimals of accuracy
[12:39:01][D][dht:048]: Got Temperature=29.2°C Humidity=90.0%
[12:39:01][D][sensor:124]: 'nodemcutwo Temperature': Sending state 29.20000 °C with 1 decimals of accuracy
[12:39:01][D][sensor:124]: 'nodemcutwo Humidity': Sending state 90.00000 % with 0 decimals of accuracy
[12:39:01][D][sensor:124]: 'nodemcutwo ssi': Sending state -43.00000 dBm with 0 decimals of accuracy
[12:39:02][D][sensor:124]: 'nodemcutwo Battery': Sending state 28.01105 % with 1 decimals of accuracy
[12:39:02][W][dht:169]: Requesting data from DHT failed!
[12:39:02][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[12:39:02][D][sensor:124]: 'nodemcutwo Temperature': Sending state nan °C with 1 decimals of accuracy
[12:39:02][D][sensor:124]: 'nodemcutwo Humidity': Sending state nan % with 0 decimals of accuracy
[12:39:02][D][sensor:124]: 'nodemcutwo ssi': Sending state -47.00000 dBm with 0 decimals of accuracy
[12:39:03][D][sensor:124]: 'nodemcutwo Battery': Sending state 28.01105 % with 1 decimals of accuracy
[12:39:03][D][dht:048]: Got Temperature=29.8°C Humidity=84.0%
[12:39:03][D][sensor:124]: 'nodemcutwo Temperature': Sending state 29.80000 °C with 1 decimals of accuracy
[12:39:03][D][sensor:124]: 'nodemcutwo Humidity': Sending state 84.00000 % with 0 decimals of accuracy
[12:39:03][D][sensor:124]: 'nodemcutwo ssi': Sending state -45.00000 dBm with 0 decimals of accuracy
[12:39:04][D][sensor:124]: 'nodemcutwo Battery': Sending state 27.87224 % with 1 decimals of accuracy
[12:39:04][I][deep_sleep:103]: Beginning Deep Sleep
the mcu sleeps for 15 mins and runs for 4 seconds…
i have tried setting retain on the sensor(not sure if this is a valid option but i get no errors and read that it fixed the problem for someone else)
i also set an expire after flag of 31 mins(to me this should make it keep the last known value after 2 cycles without an update and should then revert to unavailable)
this is driving me nuts… the temp and humidty are retained 100% of the time, but the battery level seems to revert to unavailable more than half the time it sleeps, never immediatly after a wake/reporting cycle … but when it happens it seems to happen half way through the sleep portion of the cycle
