Hi folks, I am hoping that someone could take a look at these log entries and help me diagnose.
Background:
I have two matching Nanoleaf lightstrips (51E) and I had them both working on HA and Homekit via Matter. Life was good. I was making some changes to one and removed it from HA, factory reset it, and added it back to Nanoleaf App+Homekit. For the life of me, I cannot get it re-added to HA! Running latest firmware (3.6.173).
I have it working great in Apple Home and can see it advertising on the Thread network. I follow the instructions to setup Pairing Mode in Apple Home, copy the commission code, switch to HA, add device, add Matter device, already in use, and then choose Apple Home. I paste in the commission code, and then the commissioning starts. It gives up about a minute later as indicated in the log file below.
I would appreciate any suggestions on what may be happening here. Thank you.
2024-05-27 12:59:43.881 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Discovered commissionable Matter node: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=5540, weight=0, priority=0, server='FE49ADFADA353691.local.', properties={b'VP': b'4442+68', b'SII': b'800', b'SAI': b'800', b'SAT': b'4000', b'T': b'0', b'D': b'1431', b'CM': b'2', b'RI': b'25004428916DD94BEC0E2C8C252DCFAB8E4B', b'PH': b'36', b'PI': None}, interface_index=None)
2024-05-27 12:59:45.760 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 30 (attempt 1/3).
2024-05-27 12:59:45.772 (ThreadPoolExecutor-0_1) DEBUG [matter_server.server.storage] Saved data to persistent storage
2024-05-27 12:59:55.956 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:220297824 on exchange 63864i with Node: <0000000000000000, 0> sendCount: 4 max retries: 4
2024-05-27 12:59:58.427 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 30 (attempt 2/3).
2024-05-27 12:59:59.043 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-05-27 13:00:09.366 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:220297825 on exchange 63873i with Node: <0000000000000000, 0> sendCount: 4 max retries: 4
2024-05-27 13:00:12.318 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
2024-05-27 13:00:23.959 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:24.756 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:25.942 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:26.770 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:27.957 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:28.428 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 30 (attempt 3/3).
2024-05-27 13:00:28.756 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:29.689 (MainThread) DEBUG [matter_server.server.device_controller.mdns] Commissionable Matter node disappeared: AsyncServiceInfo(type='_matterc._udp.local.', name='00D9F2F3CC4ACED3._matterc._udp.local.', addresses=[], port=None, weight=0, priority=0, server=None, properties={}, interface_index=None)
2024-05-27 13:00:39.091 (Dummy-2) CHIP_ERROR [chip.native.EM] Failed to Send CHIP MessageCounter:220297826 on exchange 63882i with Node: <0000000000000000, 0> sendCount: 4 max retries: 4
2024-05-27 13:00:41.781 (Dummy-2) CHIP_ERROR [chip.native.SC] PASESession timed out while waiting for a response from the peer. Expected message type was 33
