I’ve tried using the “Pixel” version of the OS with the same problems as mentioned above. Now writing the card with the “Jessie Lite” version and going to give it a shot.
Also, It seems SSH isn’t enabled by default on either the Pixel or Lite version. I always get connection refused.
It is possible to get Home Assistant running on Pixel. I used the info from @ken to get it working so thanks Ken
I have literally just reinstalled Home Assistant on Pixel due to an issue with HADashboard.
Once the AIO installer has completed you will also need to remove a duplicate mqtt entry in the configuration.yaml and fix the indentation. This comment was posted by another user on the forum in another thread, but I cannot find it now, so thanks who ever you are
mqtt:
broker:
port:
username:
password:
I enabled SSH and WIFI in the GUI right before disabling it
I followed Ken’s instructions and came forward in the installation. But Home Assistant not start running. I have change the IP adress in configuration.yaml, reboot the Raspberry Pi still the same problem. I dont find any duplicate for MQTT in the file.
What do I miss?
This is the first time i try Home Assistant. Would appreciate step by step instruction
For the moment just remove the mqtt entry all together, and see if you can have your system up and running. Then check if you have any mqtt broker available to use. Something like this:
Remember the indentation is one space underneath the m for the rest of the lines…
mqtt:
broker: 192.168.2.85
port: 1883
client_id: home-assistant-1
username: pi
password: xyzwww
I get this error
16-12-16 08:46:57 homeassistant.util.yaml: mapping values are not allowed here
in “/home/hass/.homeassistant/configuration.yaml”, line 46, column 9
I have changed the IP adress in the configuration.yaml to that the raspberry pi unit have, reboot. But still get the same problem.
This is probably the correct place to post as I have come through this path with the initial failure.
However, for security reasons, as well as changing the default password, I have also changed the default user name.
Installation gets to the point where it calls for a login password for ‘pi’!
Is there some way I can use a different user ID?
If I change the default name back to pi, can I later change it to a name of my choice?
yes, provided you familiarize yourself with the internals of Home Assistant. A limited service account is created during the install. Everything is installed and run under this account.
Thanks for y=the response, jbags81. I do not have a software background, but when I get to that point, I will see if I can work that out.
Having restored pi as the default user, I got further into the install, but have stopped that the point shown below:-
[localhost] out: * it needs X to run on the virtual console (VT) it was started from
[localhost] out: :
[localhost] out: :
The system is intended to run headless, so this is done on a terminal window in remote desktop on Windows 10. It has been stopped at that point for over 6 hours. I suspect it is telling me it needs some X windows program to get past that point, which I will investigate in the morning.
