I’m currently on holiday, I will have a closer look at the twice daily forecasts when I’m back
Can you show me the result of this in devtools > actions
action: weather.get_forecasts
type: twice_daily
entity_id: weather.kteb
I’m seeing some errors in vscode “Property weather is not allowed” “Property actions is not allowed” "Property triggers is not allowed.
It seems to be working fine, and under Developer Tools no errors are showing. Anything to be worried about?
No, nothing to worry about. This is just the HA config checker extension in VSCode not being up to date with all recent changes in the template integration.
@mynolix1986
I fixed the issue in the new version I’ve put online now.
Note that I also changed how the weight is provided, it is now a list instead of a dictionary. I did this in preparation to create a template blueprint for this template weather.
Update
BREAKING
weightis now provided as a list with dictionaries, instead of a named dictionary. This is in preparation of creating a template blueprint for the combined weather. It makes it easier to provide GUI support when this is released for template blueprints.
IMPROVEMENTS
- A
twice_dailyforecast will now be created based on thehourlyforecast in case there are no weather integrations which provide it
BUG FIXES
twice_dailyforecasts were not created correctly (the requiredis_daytimeforecast attribute was not provided). This has now been fixed, so if you have a weather integration providing atwice_dailyforecast, it will now also be visible (and combined with others).
Update
IMPROVEMENTS
- Changed the trigger to trigger every 5 minutes instead of every hour. When the trigger is on every hour, the current values (like current temperature and humidity) are also only updated hourly, which means they are lagging behind.
- Moved the calculation of the current attributes (like current temperature and humidity) to the
actionsection to reduce duplicate code
BUG FIXES
- fixed several cases where I didn’t properly use the new format to provide weights.
Thank you for great , reliable add on to our HA. I have 2 questions
1- How to update existing YAML file ? Just copy and paste entire file from your github page or some portions need to be updated?
2- When you will post template blueprint for combined forecast, what we have o do?
Download blueprint and it will update existing one, or we have to remove old files and start using blueprint?
Thank you in advanced . I think blueprint is a brilliant idea , specially for people who is not comfortable to modify YAML code.
Updating the current version would indeed mean replacing the current file with the new one.
But if you’ve set weight you need to make sure it’s adjusted to the new format, and added in the right spot in the code.
Regarding the blueprint there is currently no support for the GUI yet, so also there changes in the settings (like weight or the unit of measurements) need to be done in YAML. However, the underlying code for the calculations can be updated independently of the settings.
I have the bleuprint ready, but I’m not mentioning it yet because:
- changes to template blueprints are expected regarding how unique id’s are set, which might make it that the current version needs adjustments which break it for already installed setups
- currently only one template entity can be created using a blueprint, which will make the current setup with the additional sensors impossible. Also this is something that might change in the future
- there is no GUI support yet, which gives it not much additional benefit over the current setup
However, if you really want you can import the blueprint here
A full example how to then use it can be found here
Important:
- this will only create the template weather, not the additional sensors
- this might break in the future
@dovy6 Are you using the latest version?
Wait, did you change the unit of measurement for temperature to °F? If it’s still on °C it’s using you Fahrenheit input as Celcius, and then HA converts that to Fahrenheit again, resulting in a value which will be too high.
You need to change all units of measurement to the ones your integrations are providing
That was exactly it. I had initially changed it to F, but when I just updated to the latest version, you moved the unit section, and I had accidently changed everything back to metric. Changing it back to °F has fixed the issue, and temps are back down to the slightly more sane 80 degrees.
Thanks!
After updating HA to 2026.1 the following error after each restart:
Logger: homeassistant.components.weather
Source: helpers/entity_platform.py:684
integration: Weather (documentation, issues)
First occurred: 12:43:46 (1 occurrence)
Last logged: 12:43:46
Error adding entity weather.combined for domain weather with platform template
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 684, in _async_add_entities
await self._async_add_entity(
entity, False, entity_registry, config_subentry_id
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 1010, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1380, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1024, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1149, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1088, in __async_calculate_state
if state_attributes := self.state_attributes:
File "/usr/src/homeassistant/homeassistant/components/weather/__init__.py", line 614, in state_attributes
data[ATTR_WEATHER_HUMIDITY] = round(humidity)
TypeError: type str doesn't define __round__ method
Using this one and not the blueprint.
I see it myself for both the blueprint and the other setup.
I’ll have a look at it. Right now the weather entity does seem to work.
Thanks! ![]()
The entity is indeed working, the error shows up during restart.
HA 2026.7 will introduce a change which will break the combined weather entity. I already applied a quick fix.
So if you want the combined weather to work after you update to 2026.7, make sure to update the combined weather code to the latest version.
You can already do that before updating HA, the fix isn't breaking on older versions.
Any hint as to what changed in 2026.7 that caused this to break?
Yes. Entity attribute keys can now be an enum.
To avoid repeating the same code I built a dictionary with all available attribute keys and the median values of all weather entities. This is the current_values variable which is then used in the template weather for e.g. the current humidity and the current ozone value.
However, HA was not able to store the variable when the keys of this dictionary were enum values. So this gave an error, and then broke further processing of the template weather. As a quick fix I converted the list of attribute keys to a json string, and then back to a list using | to_json | from_json which made it use te string representations of the enum values.
It has been discussed on Discord last Wednesday and it was decided to not revert the change as it was expected that the impact would be rather low. It will be investigated though, and a proper solution will be implemented.
