I have a lot of 1wire sensors, like DS18B20, and I cant connect it directly (big range)
Can anyone suggest me, what I need to use to connect it to hassio?
I have zigbee2mqtt, so whih method more cheaper?
(I can connect every sensor to arduino/esp8266, but I hope, there is more lovely desicion)
ESPhome is an addon to hassio that makes it easy to program ESP wifi boards like the Wemos D1 mini with simple yaml configuration files. It supports your temperature sensors. See an example here:
All you would need at the location is either 3.3V or 5V power (500mA).
