So you ran the bellows directly without HASS?
I have some zigbee dongles and I tried to start the bellows cli but it seem’s that I dont fully understand how to pass the parameters to bellows.
This is what I tried but zero success…
bellows -d COM3
Error: Invalid value for “-d” / “–device”: Path “COM3” does not exist.
Can you give me an example how you started the bellows cli?
A French guy is now working on such gateway, he his the only one I’ve heard of that successfully reversed engineer the Xiaomi protocol!
His homemade bridge support Philips Hue, Xiaomi sensor/light, Light Link, Toshiba Pluzzy and he’ll also integrate support for Ikea line of product.
He’s preparing a Kickstarter campaign to sell he’s bridge (but will also share his code/hardware).
If you understand French you can find more info on his website:
hijinx
(James)
May 24, 2017, 2:44pm
23
Google translate works very well, too.
Hi, Are you on Windows? I assume so as you’re specifying COM3 rather than /dev/ttyUSBn.
Yes but I also tried to run te bellows in lubuntu and results were pretty much the same…
bellows -d /dev/ttyACM1
I ran “bellows -v debug -d /dev/ttyUSB1 info” I suspect you may be selecting the wrong device, are you sure /dev/ttyACM1 is the stick? What device do you have?
I will check the path again. I have cc2531 stick and I know it won’t work without rewriting part of the bellows repo. I have been fidling around a bit with zigbee4java, which works with cc2531. So may be I can port needed parts from zigbee4java to get the bellows working with cc2531. At least in theory this should be possible😜
If you get your stick working, I will just order one and stop playing with the cc2531.
rcloran
(Russell Cloran)
June 3, 2017, 6:44am
28
It looks like you’re using a firmware that uses EZSP protocol version 5. Support was added to bellows for that recently, but it’s not yet been released. Could you try to install bellows master and see if it works?
rcloran
(Russell Cloran)
June 3, 2017, 6:49am
29
https://github.com/rcloran/bellows/issues/16
You should be able to work around this by changing line 26-31 in bellows/cli/opts.py to just be type=click.STRING
. I haven’t tested that yet, though.
Hi thanks for your help,
Looking good, we’re getting further along after I pulled the latest code from your git repo.
I’m now getting the following when I call zha “permit”:
ERROR:homeassistant.core:Error doing job: Exception in callback SerialTransport._read_ready()
File “/usr/lib/python3.4/asyncio/events.py”, line 120, in _run
self._callback(*self._args)
File “/opt/hass/.homeassistant/deps/serial_asyncio/init .py”, line 106, in _read_ready
self._protocol.data_received(data)
File “/opt/hass/.homeassistant/deps/bellows/uart.py”, line 61, in data_received
self.frame_received(frame)
File “/opt/hass/.homeassistant/deps/bellows/uart.py”, line 73, in frame_received
self.data_frame_received(data)
File “/opt/hass/.homeassistant/deps/bellows/uart.py”, line 94, in data_frame_received
self._application.frame_received(self.randomize(data[1:-3]))
File “/opt/hass/.homeassistant/deps/bellows/ezsp.py”, line 179, in frame_received
result, data = t.deserialize(data, schema)
File “/opt/hass/.homeassistant/deps/bellows/types/init .py”, line 9, in deserialize
value, data = type .deserialize(data)
File “/opt/hass/.homeassistant/deps/bellows/types/basic.py”, line 13, in deserialize
r = cls(int.from_bytes(data[:cls._size], ‘little’, signed=cls._signed))
File “/usr/lib/python3.4/enum.py”, line 222, in call
return cls.new (cls, value)
File “/usr/lib/python3.4/enum.py”, line 457, in new
raise ValueError(“%r is not a valid %s” % (value, cls.name ))
ValueError: 6 is not a valid EmberOutgoingMessageType
And then the following when the device joins:
DEBUG:bellows.ezsp:Application frame 63 (messageSentHandler) received
DEBUG:bellows.uart:Data frame: b’1556b157546f15b658944a24ab5593499c59d8770af29874f8de6782fcbf132d7e’
DEBUG:bellows.uart:Sending: b’82503a7e’
DEBUG:bellows.ezsp:Application frame 69 (incomingMessageHandler) received
ERROR:homeassistant.core:Error doing job: Task exception was never retrieved
File “/usr/lib/python3.4/asyncio/tasks.py”, line 237, in _step
result = next(coro)
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/zha/init .py”, line 142, in async_device_initialized
discovered_info = yield from _discover_endpoint_info(endpoint)
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/zha/init .py”, line 269, in _discover_endpoint_info
allow_cache=True,
File “/opt/hass/.homeassistant/deps/bellows/zigbee/zcl/init .py”, line 183, in read_attributes
for record in result[0]:
TypeError: ‘uint8_t’ object is not iterable
Looks like there’s still a few things to be tweaked but it feels like it’s almost there.
rcloran
(Russell Cloran)
June 9, 2017, 11:10am
31
Those both seem very strange to me (eg, there is no EmberOutgoingMessageType 6 in the spec). Unfortunately, I don’t have an EZSP 5 device to test with. I’ve created
https://github.com/rcloran/bellows/issues/18 (permit issue)
https://github.com/rcloran/bellows/issues/19 (device join issue)
I see you had debug logging on in the second case. It’d really help if you could get it on in the first, and provide more of the previous log lines. What would be ideal would be the output of bellows -d yourdevicepath -v debug permit
. If you can put that on the github issue that’d be great.
Thanks for the update, I’ve pulled the latest version and posted the output to the first issue.
Looks like it’s still not quite there yet:
DEBUG:bellows.uart:Data frame: b'104db157540e9c95a77d8325aa738acd9d4e27ab54077e'
DEBUG:bellows.uart:Sending: b'82503a7e'
DEBUG:bellows.ezsp:Application frame 36 (trustCenterJoinHandler) received
INFO:bellows.zigbee.application:Device 0x2789 (84:18:26:00:00:c9:e9:fe) joined the network
INFO:bellows.zigbee.device:[0x2789] Discovering endpoints
DEBUG:bellows.ezsp:Send command sendUnicast
DEBUG:bellows.uart:Sending: b'02522157541e153b7d5e944a20aa5592099d4e27aaeccd6602da3fb97e'
DEBUG:bellows.uart:Data frame: b'2152a157541e158d0a947e'
DEBUG:bellows.uart:Sending: b'83401b7e'
DEBUG:bellows.ezsp:Application frame 52 (sendUnicast) received
DEBUG:bellows.uart:Data frame: b'3152b1575415153b7e944a20aa5592099d4e2794eca867e17b7e'
DEBUG:bellows.uart:Sending: b'8430fc7e'
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/root/.homeassistant/deps/bellows/zigbee/device.py", line 39, in initialize
epr = yield from self.zdo.request(0x0005, self._nwk)
File "/root/.homeassistant/deps/bellows/zigbee/application.py", line 260, in request
v = yield from send_fut
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
Exception: Message send failure: EmberStatus.DELIVERY_FAILED
DEBUG:bellows.uart:Data frame: b'4152b157540e9c95a77d8325aa738acd9d4e27ab2df67e'
DEBUG:bellows.uart:Sending: b'8520dd7e'
DEBUG:bellows.uart:Sending: b'15532157541e153b7d5e944a20aa5592099d4e27a9efcd6502daa2317e'
DEBUG:bellows.uart:Data frame: b'5253a157541e15f355d57e'
DEBUG:bellows.uart:Sending: b'8610be7e'
DEBUG:bellows.uart:Data frame: b'6253b1575415153b7e944a20aa5592099c4e27eaefa867d30e7e'
DEBUG:bellows.uart:Sending: b'87009f7e'
This was trying to add a Osram lightify bulb, same error with my Innr light strip.
Any suggestions?
Wish I could post better news, trying to add an Osram lightify bulb again. Still looks like it’s got some issues I’m afraid:
2017-07-24 19:17:56 INFO (MainThread) [homeassistant.setup] Setting up zha
2017-07-24 19:17:57 DEBUG (MainThread) [bellows.zigbee.appdb] Loading application state from /opt/hass/zigbee.db
2017-07-24 19:17:57 DEBUG (MainThread) [bellows.uart] Sending: b'1ac038bc7e'
2017-07-24 19:17:57 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-07-24 19:17:57 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2017-07-24 19:17:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] RSTACK Version: 2 Reason: RESET_SOFTWARE frame: b'c1020b0a527e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command version
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'004221a850ed2c7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'0142a1a8512805ebd87b7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'8160597e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 0 (version) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Switching to eszp version 5
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'7d31432157542a1025c57e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'1243a157542a10b049cd89937e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'82503a7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command setConfigurationValue
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'22402157547919b059c46e7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'2340a157547915fbd27e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'83401b7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 83 (setConfigurationValue) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'3341215754797d38b75995c77e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'3441a157547915904d7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'8430fc7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'44462157547938b35902ad7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'4546a157547915640c7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'8520dd7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'5547215754793fb1591e517e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'5647a157547915ce557e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'8610be7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'6644215754790cb059a0a67e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'6744a157547915e1597e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'87009f7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'774521575479144d59d0f77e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'7045a1575479158ac67e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'8070787e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command networkInit
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'004a2157543de6f77e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'014aa557543d153bcb7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 23 (networkInit) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'114ab157543385215a7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 25 (stackStatusHandler) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command getNetworkParameters
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'124b215754027d3ade7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'224ba157540215b349ddd31cba75d2c21b6fd9a5edce678bfd3e9c8e422a7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 40 (getNetworkParameters) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command setPolicy
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'23482157547f10e25bc07e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'3348a157547f156b4d7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 85 (setPolicy) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'34492157547f7d33d36a2c7e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'4449a157547f15b3c87e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'454e2157547f15b342b77e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'554ea157547f15f4937e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command getNodeId
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'564f2157540d0e867e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'664fa157540d15b23ba27e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 39 (getNodeId) received
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Send command getEui64
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Sending: b'674c2157540c9a597e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.uart] Data frame: b'774ca157540ccf0450944a86885527a57e'
2017-07-24 19:17:58 DEBUG (MainThread) [bellows.ezsp] Application frame 38 (getEui64) received
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=permit, domain=zha>
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.setup] Setup of domain zha took 2.1 seconds.
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=zha>
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.65s
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
2017-07-24 19:17:58 INFO (MainThread) [homeassistant.core] Timer:starting
2017-07-24 19:18:14 INFO (MainThread) [homeassistant.components.http] Serving /states to 192.168.100.2 (auth: True)
2017-07-24 19:18:20 DEBUG (MainThread) [bellows.uart] Data frame: b'074cb157546f10b2598b4a25aa5592499cb1d8abedce9874f7476288c96e3da663dade32307e'
2017-07-24 19:18:20 DEBUG (MainThread) [bellows.uart] Sending: b'8160597e'
2017-07-24 19:18:20 DEBUG (MainThread) [bellows.ezsp] Application frame 69 (incomingMessageHandler) received
2017-07-24 19:18:20 DEBUG (MainThread) [bellows.zigbee.application] No such device 0
2017-07-24 19:18:20 WARNING (MainThread) [bellows.zigbee.zdo] Unknown ZDO cluster 0x1f
2017-07-24 19:18:20 WARNING (MainThread) [bellows.zigbee.application] Message on unknown device 0x0000
2017-07-24 19:18:21 DEBUG (MainThread) [bellows.uart] Data frame: b'174cb1575415134ea6944a3aaa5592499c4e2754edce67a57b7e'
2017-07-24 19:18:21 DEBUG (MainThread) [bellows.uart] Sending: b'82503a7e'
2017-07-24 19:18:21 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:18:21 WARNING (MainThread) [bellows.zigbee.application] Unexpected message send notification
2017-07-24 19:18:22 INFO (MainThread) [homeassistant.components.http] Serving /states to 192.168.100.2 (auth: True)
2017-07-24 19:18:42 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 192.168.100.2 (auth: True)
2017-07-24 19:18:42 INFO (MainThread) [homeassistant.components.http] Serving /api/themes to 192.168.100.2 (auth: True)
2017-07-24 19:18:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=, service_call_id=1978596752-1, service=permit, domain=zha>
2017-07-24 19:18:52 INFO (MainThread) [homeassistant.components.zha] Permitting joins for 60s
2017-07-24 19:18:52 DEBUG (MainThread) [bellows.ezsp] Send command permitJoining
2017-07-24 19:18:52 DEBUG (MainThread) [bellows.uart] Sending: b'724d215754082909007e'
2017-07-24 19:18:52 DEBUG (MainThread) [bellows.uart] Data frame: b'204da157540815567b7e'
2017-07-24 19:18:53 DEBUG (MainThread) [bellows.uart] Sending: b'83401b7e'
2017-07-24 19:18:53 DEBUG (MainThread) [bellows.ezsp] Application frame 34 (permitJoining) received
2017-07-24 19:18:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1978596752-1>
2017-07-24 19:18:54 DEBUG (MainThread) [bellows.uart] Data frame: b'304db157540915b3a3904b10ba5793c18b4e232bab7e'
2017-07-24 19:18:54 DEBUG (MainThread) [bellows.uart] Sending: b'8430fc7e'
2017-07-24 19:18:54 DEBUG (MainThread) [bellows.ezsp] Application frame 35 (childJoinHandler) received
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.uart] Data frame: b'404db157540eefb658a15a27abdd85499d4e27abf4f97e'
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.uart] Sending: b'8520dd7e'
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:18:55 INFO (MainThread) [bellows.zigbee.application] Device 0x04fa (00:17:88:01:02:10:35:01) joined the network
2017-07-24 19:18:55 INFO (MainThread) [bellows.zigbee.device] [0x04fa] Discovering endpoints
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.uart] Sending: b'05522157541e15485d944a20aa5592099d4e27aaeccd6671f94f767e'
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.uart] Data frame: b'5152a157541e151a49c67e'
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.uart] Sending: b'8610be7e'
2017-07-24 19:18:55 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.uart] Data frame: b'6152b157540eaa13a77d8325aa738acd9d4e27ab91c47e'
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.uart] Sending: b'87009f7e'
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:19:01 INFO (MainThread) [bellows.zigbee.application] Device 0xa1bf (84:18:26:00:00:c9:e9:fe) joined the network
2017-07-24 19:19:01 INFO (MainThread) [bellows.zigbee.device] [0xa1bf] Discovering endpoints
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.uart] Sending: b'17532157541e150df8944a20aa5592099d4e27a9efcd65345ce2a47e'
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.uart] Data frame: b'7253a157541e151862f87e'
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.uart] Sending: b'8070787e'
2017-07-24 19:19:01 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:02 DEBUG (MainThread) [bellows.uart] Data frame: b'0253b15754aa57485de54e7e'
2017-07-24 19:19:02 DEBUG (MainThread) [bellows.uart] Sending: b'8160597e'
2017-07-24 19:19:02 DEBUG (MainThread) [bellows.ezsp] Application frame 128 (incomingRouteErrorHandler) received
2017-07-24 19:19:06 DEBUG (MainThread) [bellows.uart] Data frame: b'1253b1575415150df8944a20aa5592099d4e2701efa86747047e'
2017-07-24 19:19:06 DEBUG (MainThread) [bellows.uart] Sending: b'82503a7e'
2017-07-24 19:19:06 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:07 DEBUG (MainThread) [bellows.uart] Data frame: b'2253b15754aa57485d42b27e'
2017-07-24 19:19:07 DEBUG (MainThread) [bellows.uart] Sending: b'83401b7e'
2017-07-24 19:19:07 DEBUG (MainThread) [bellows.ezsp] Application frame 128 (incomingRouteErrorHandler) received
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Sending: b'23502157541e150df8944a20aa5592099d4e27a8eecd64345c49dd7e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Data frame: b'3350a157541e15191b587e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Sending: b'8430fc7e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Data frame: b'4350b157540eaa13a77d8325aa738acd9d4e27ab801b7e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Sending: b'8520dd7e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:19:08 INFO (MainThread) [bellows.zigbee.application] Device 0xa1bf (84:18:26:00:00:c9:e9:fe) joined the network
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.zigbee.application] Skip initialization for existing device 84:18:26:00:00:c9:e9:fe
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Data frame: b'5350b157541515485d944a20aa5592099d4e2703eca867b9117e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.uart] Sending: b'8610be7e'
2017-07-24 19:19:08 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.uart] Data frame: b'6350b157540915b3a3904b10ba5793c18b4e23ab847e'
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.uart] Sending: b'87009f7e'
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.ezsp] Application frame 35 (childJoinHandler) received
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.uart] Sending: b'37512157541e15485d944a20aa5592099d4e27afe9cd6371f93af17e'
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.uart] Data frame: b'7451a157541e151ff2377e'
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.uart] Sending: b'8070787e'
2017-07-24 19:19:10 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:11 DEBUG (MainThread) [bellows.uart] Data frame: b'0451b157540eefb658a15a27abdd85499d4e27ab77247e'
2017-07-24 19:19:11 DEBUG (MainThread) [bellows.uart] Sending: b'8160597e'
2017-07-24 19:19:11 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:19:11 INFO (MainThread) [bellows.zigbee.application] Device 0x04fa (00:17:88:01:02:10:35:01) joined the network
2017-07-24 19:19:11 DEBUG (MainThread) [bellows.zigbee.application] Skip initialization for existing device 00:17:88:01:02:10:35:01
2017-07-24 19:19:12 DEBUG (MainThread) [bellows.uart] Data frame: b'1451b1575415150df8944a20aa5592099c4e2700eea8672b4a7e'
2017-07-24 19:19:12 DEBUG (MainThread) [bellows.uart] Sending: b'82503a7e'
2017-07-24 19:19:12 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:14 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:19:14 DEBUG (MainThread) [bellows.uart] Sending: b'42562157541e150df8944a20aa5592099d4e27aee8cd62345c143f7e'
2017-07-24 19:19:14 DEBUG (MainThread) [bellows.uart] Data frame: b'2556a157541e151d47867e'
2017-07-24 19:19:14 DEBUG (MainThread) [bellows.uart] Sending: b'83401b7e'
2017-07-24 19:19:14 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:15 DEBUG (MainThread) [bellows.uart] Data frame: b'3556b157540eaa13a77d8325aa738acd9d4e27abd9297e'
2017-07-24 19:19:15 DEBUG (MainThread) [bellows.uart] Sending: b'8430fc7e'
2017-07-24 19:19:15 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:19:15 INFO (MainThread) [bellows.zigbee.application] Device 0xa1bf (84:18:26:00:00:c9:e9:fe) joined the network
2017-07-24 19:19:15 DEBUG (MainThread) [bellows.zigbee.application] Skip initialization for existing device 84:18:26:00:00:c9:e9:fe
2017-07-24 19:19:19 DEBUG (MainThread) [bellows.uart] Data frame: b'4556b1575415150df8944a20aa5592099d4e2704e8a8676ef67e'
2017-07-24 19:19:19 DEBUG (MainThread) [bellows.uart] Sending: b'8520dd7e'
2017-07-24 19:19:19 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:19 WARNING (MainThread) [bellows.zigbee.device] [0xa1bf] Failed ZDO request during device initialization: Message send failure: EmberStatus.DELIVERY_FAILED
2017-07-24 19:19:22 DEBUG (MainThread) [bellows.uart] Data frame: b'5556b15754aa57485d107c7e'
2017-07-24 19:19:22 DEBUG (MainThread) [bellows.uart] Sending: b'8610be7e'
2017-07-24 19:19:22 DEBUG (MainThread) [bellows.ezsp] Application frame 128 (incomingRouteErrorHandler) received
2017-07-24 19:19:23 DEBUG (MainThread) [bellows.uart] Data frame: b'6556b157546f15b259acca25aa1593499cffd8abedce9874e6c66389048138b3ebc6de7f4e2c7b106611d041f68e1855cd89094664607e'
2017-07-24 19:19:23 DEBUG (MainThread) [bellows.uart] Sending: b'87009f7e'
2017-07-24 19:19:23 DEBUG (MainThread) [bellows.ezsp] Application frame 69 (incomingMessageHandler) received
2017-07-24 19:19:23 DEBUG (MainThread) [bellows.zigbee.application] No such device 0
2017-07-24 19:19:23 WARNING (MainThread) [bellows.zigbee.zdo] Unknown ZDO cluster 0x8038
2017-07-24 19:19:23 WARNING (MainThread) [bellows.zigbee.application] Unexpected response TSN=0 command=32824 args=b'\x00\x00\xf8\xff\x07\x14\x00\x0b\x00\x10\xc1\xd3\xbc\xcb\xb3\xc3\xb9\xcd\xb0\xad\xb1\xb9\xbb\xb2\xac\xac'
2017-07-24 19:19:23 WARNING (MainThread) [bellows.zigbee.application] Message on unknown device 0x0000
2017-07-24 19:19:24 DEBUG (MainThread) [bellows.uart] Data frame: b'7556b157541515485d944a20aa5592099d4e2706e9a867bca27e'
2017-07-24 19:19:24 DEBUG (MainThread) [bellows.uart] Sending: b'8070787e'
2017-07-24 19:19:24 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:26 DEBUG (MainThread) [bellows.ezsp] Send command sendUnicast
2017-07-24 19:19:26 DEBUG (MainThread) [bellows.uart] Sending: b'50572157541e15485d944a20aa5592099d4e27adebcd6171f9b9ed7e'
2017-07-24 19:19:26 DEBUG (MainThread) [bellows.uart] Data frame: b'0657a157541e15008f667e'
2017-07-24 19:19:26 DEBUG (MainThread) [bellows.uart] Sending: b'8160597e'
2017-07-24 19:19:26 DEBUG (MainThread) [bellows.ezsp] Application frame 52 (sendUnicast) received
2017-07-24 19:19:29 DEBUG (MainThread) [bellows.uart] Data frame: b'1657b15754aa57485d25327e'
2017-07-24 19:19:29 DEBUG (MainThread) [bellows.uart] Sending: b'82503a7e'
2017-07-24 19:19:29 DEBUG (MainThread) [bellows.ezsp] Application frame 128 (incomingRouteErrorHandler) received
2017-07-24 19:19:31 DEBUG (MainThread) [bellows.uart] Data frame: b'2657b157540915b3a3904b10ba5793c18b4e230c257e'
2017-07-24 19:19:31 DEBUG (MainThread) [bellows.uart] Sending: b'83401b7e'
2017-07-24 19:19:31 DEBUG (MainThread) [bellows.ezsp] Application frame 35 (childJoinHandler) received
2017-07-24 19:19:32 DEBUG (MainThread) [bellows.uart] Data frame: b'3657b157540eefb658a15a27abdd85499d4e27ab45b77e'
2017-07-24 19:19:32 DEBUG (MainThread) [bellows.uart] Sending: b'8430fc7e'
2017-07-24 19:19:32 DEBUG (MainThread) [bellows.ezsp] Application frame 36 (trustCenterJoinHandler) received
2017-07-24 19:19:32 INFO (MainThread) [bellows.zigbee.application] Device 0x04fa (00:17:88:01:02:10:35:01) joined the network
2017-07-24 19:19:32 DEBUG (MainThread) [bellows.zigbee.application] Skip initialization for existing device 00:17:88:01:02:10:35:01
2017-07-24 19:19:39 DEBUG (MainThread) [bellows.uart] Data frame: b'4657b157541515485d944a20aa5592099d4e2719eba8678fd47e'
2017-07-24 19:19:39 DEBUG (MainThread) [bellows.uart] Sending: b'8520dd7e'
2017-07-24 19:19:39 DEBUG (MainThread) [bellows.ezsp] Application frame 63 (messageSentHandler) received
2017-07-24 19:19:39 WARNING (MainThread) [bellows.zigbee.device] [0x04fa] Failed ZDO request during device initialization: Message send failure: EmberStatus.DELIVERY_FAILED
2017-07-24 19:19:53 DEBUG (MainThread) [bellows.uart] Data frame: b'5657b157540915b2a3904b10ba5793c18b4e239ec37e'
2017-07-24 19:19:53 DEBUG (MainThread) [bellows.uart] Sending: b'8610be7e'
2017-07-24 19:19:53 DEBUG (MainThread) [bellows.ezsp] Application frame 35 (childJoinHandler) received
andrewpc
(Andrew)
August 10, 2017, 4:14am
37
@MindrustUK Any updates on getting this stick working? Thinking of purchasing the same one.
Hi @andrewpc
Unfortunately not, I’m still seeing various errors even with bellows 0.3.5, at present it might be worth looking at alternatives.
mje-nz
December 10, 2017, 10:29pm
39
Sorry to resurrect this thread, but did you end up getting the SiLabs stick to work? There’s another thread about the ETRX357USB where they had to flash it with EZSP 4 firmware to get it to work.
I’ve been poking at this as the code matures but not had a great amount of success. I think the issues are related mainly to unhanded clusters but I’ll certainly try the EZSP 4 firmware and see what results I get. In the mean time I’ve also been trying http://zigate.fr/ which needs more work in getting the code right but seems the most promising solution I’ve found so far.
