I bought a very cool sensor #OneMeter (onemeter.com) that works very well with my electricity meter and smartphone on Android.
On Android smartphone everything works beautifully, but unfortunately I can’t pair with my computer.
Someone has #OneMeter device and knows how to connect it to Home Assistant?
I have a Bluetooth LE receiver plugged into my computer by USB and finds OneMeter without any problem, but I can’t pair this device on Windows. I can’t pair on my Android phone either, but the original application can find the OneMeter without any problems and works fine.
my configuration: Windows 10, 64-bit, last version of HA
I have bought such a device too… the integration into HA is working fine so fare. I have modifier the solution from “onemeter” website a bit in case a value doesn’t exist
There are many things in the app what works weirdly. That is one of those. I cannot remember seeing that value changing from 0 to anything else.
But my guess would be that you need a meter which supports that or an Enterprise unit to use the DSR Mode. For current power usage I assume you would need the 1 minute readout.
