#OneMeter problems :-(
I bought a very cool sensor #OneMeter (onemeter.com) that works very well with my electricity meter and smartphone on Android.
On Android smartphone everything works beautifully, but unfortunately I can’t pair with my computer.
Someone has #OneMeter device and knows how to connect it to Home Assistant?
I have a Bluetooth LE receiver plugged into my computer by USB and finds OneMeter without any problem, but I can’t pair this device on Windows. I can’t pair on my Android phone either, but the original application can find the OneMeter without any problems and works fine.
my configuration: Windows 10, 64-bit, last version of HA
Somebody can help me?
This is the wrong forum :wink: This is a home assistant forum, you need to ask this in the Domoticz forum
That’s right, of course I mean about HA, because I tested different home automation services. Thank you I re-edited my post above for HA.
My question is still actuall for HA of course :slight_smile:
There is no integration written for home assistant.
The device communicates using encrypted BLE to a smartphone.
There is no public API so it looks like you might have to create some web scrape sensors for the device’s cloud web page.
I asked #OneMeter for support and API, but unfortunately no answer :frowning:
I would like to make a local connection directly from sensor to computer (without reading from the cloud).
Have you seen this: https://onemeter.com/blog/onemeter-on-home-assistant/
The article guides you on how to integrate OneMeter with Home Assistant through the OneMeter API.
Nice that they posted a solution but it is cloud based. And…
@radzik75
Just leaving here a note, as I have been in contact with Onemeter recently.
They had in the plans for a while to release a local MQTT solution but it is still work in progress.
They told me this in an email:
when are you planning to release a local MQTT solution for the Gateway?
It depends on clients’ needs. For now we haven’t registered a high demand of this feature. I think the perspective of Q2/Q3 2022 is reasonable.
So if anybody interested in the local MQTT setup through their Gateway, just drop a message to them through their contact for.
Otherwise they are just extending their market to the Czech Republic and Germany according to a recent post on their Facebook page:
https://fb.watch/c98Vfry0O3/
I have bought such a device too… the integration into HA is working fine so fare. I have modifier the solution from “onemeter” website a bit in case a value doesn’t exist
https://community.home-assistant.io/t/rewrite-a-code/313716/11
My problem is that the “current power usage” is always zero.
grafik
There are many things in the app what works weirdly. That is one of those. I cannot remember seeing that value changing from 0 to anything else.
But my guess would be that you need a meter which supports that or an Enterprise unit to use the DSR Mode. For current power usage I assume you would need the 1 minute readout.
I don’t have the device anymore. I did send it back and bought one of these
frient Electricity Meter Interface
that one gives me the current power usage and the consumption
I have connected if with deCONZ and a Conbee II stick.
I have one of those as well, but my preference is the Onemeter one as I use it with a PV installation.
I wanted to modify the frient one to work with my gas meter, but I haven’t sorted out yet the reed or magnetic sensor and the connector wiring.
