Hi All,
Has anyone managed to integrate the Onforu wifi Security lights into home assistant? I’m not sure if these are just Tuya devices, be integrated directly, or flashed with another firmware.
Also Bump, Not finding a lot of info on these - I can integrate with google home, which is obviously not preferred. Anyone have any luck nailing down these?
Just bumping this up. Still hoping someone has figured out a way to get these into home assistant. For anyone unfamiliar with them, they are pretty nice lights for a very low cost on Amazon.
Looks like it does use cbu (bk7231n)
So you can flash it esphome/openbeken
Assuming the tuya firmware’s not patched yet, you can just flash ota using cloudcutter without any teardown
Thank you for pointing me in the right direction @ferbulous. If I decide to go down this route, I’ll be sure to post my findings for anyone else interested.
Just did a tuya-cloudcutter OTA flash for my 100w onforu wifi flood motion light which is the same as the one linked above, jut more LEDs, I used the mfg/model from that 55w model and was successful in making it a local esphome device. Here’s the config with the default motion detection enabled, or you can remove it and drive everything via automations. Enjoy.
On a whim, I merely added the 100w, non motion sensor, variant of this floodlight into the tuya app I already had for other devices, put the lights into pairing mode (light switch on off on off on) and the tuya app found them easily. Then added the 2 lights via tuya in HA. No problem, works flawlessly with no flash, no fuss.
I thought I’d hop in here and provide an update. I followed @calco88 's guidance and was able to flash esphome using tuya-cloudcutter.The config provided worked perfectly. No more cloud!
