Hello! I use Nabu Casa/Home Assistant Cloud and I have 4 Onju around the house to which I give a command, it executes it and it answers “I turned on the light” but then it doesn’t answer anymore !!! Only once ! after if I remove the power or restart HA it goes again but still only once!
All 4 do the same.
With Jabra it works perfectly!
Thank you
There are some problem with esphome 2024.5 , next update should solve it or you can go back restoring a 2024.4 partial backup.
Thank you very much! I succeeded with the add on https://github.com/khenderick/esphome-legacy-addons
