Onkyo Integration Needs CBL/SAT
I am using the Onkyo integration and have set the following sources in the configuration.yaml to test:
sources:
  cd: "CD"
  cbl/sat: "Xfinity"
  phono: "Phono"
The cd and phono work as expected but the cbl/sat will not switch (I did notice it is not in the default list either).
Can this be added to the integrations acceptable sources?
Thanks!
My onkyo switches to cbl/sat if i add “video2” into ha config.
Thanks Pavel! That worked.
