Originally filed as a bug against the Onkyo integration… and asked to file here… https://github.com/home-assistant/core/issues/75221
Issue
Amongst other issues related to unique IDs, the UI can not modify entities without unique IDs. This means that one can not hide/rename/assign locations/etc on an entity by entity basis.
Practical examples:
- Add Onkyo AVR with 2 zones. 3 entities are created. , Zone 2, Zone 3 with NO way to hide or even remove the bogus zone 3.
- Above example again. In the case of zones 2 (and to some small extent zone 1), it is EXTREMELY useful to place the zones I the appropriate Areas. This is impossible without unique IDs.
- Finally friendly naming of entities would bee MUCH easier if entities have unique IDs rather then current workaround of manually customizing each of the Onkyo’s mediaplayer entities as I did in YAML per: [Customizing entities - Home Assistant]
Integration causing the issue
Onkyo
Link to integration documentation
Additional information
I was a software engineer for 20+ years at a certain “fruit” company here in the Bay area and do possess some reasonable dev skills and would help if I could on this but unfortunately pretty new to HA and it’s related internal core concepts (terminology, architecture/design, and internals). If I can help or further clarification is needed, please let me know.
