Is anyone else seeing errors in their log for the Onkyo integration?
2023-05-08 16:45:39.902 ERROR (MainThread) [homeassistant.components.media_player] onkyo: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 521, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 784, in async_device_update
await coro
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/onkyo/media_player.py", line 295, in update
status = self.command("system-power query")
File "/usr/src/homeassistant/homeassistant/components/onkyo/media_player.py", line 282, in command
result = self._receiver.command(command)
File "/usr/local/lib/python3.10/site-packages/eiscp/core.py", line 480, in command
response = self.raw(iscp_message)
File "/usr/local/lib/python3.10/site-packages/eiscp/core.py", line 470, in raw
return filter_for_message(self.get, iscp_message)
File "/usr/local/lib/python3.10/site-packages/eiscp/core.py", line 260, in filter_for_message
candidate = getter_func(0.05)
File "/usr/local/lib/python3.10/site-packages/eiscp/core.py", line 443, in get
ready = select.select([self.command_socket], [], [], timeout or 0)
TypeError: argument must be an int, or have a fileno() method.
I wasn’t getting these errors before, but just eyeballing the stack-trace, I can see that self.command("system-power query")
isn’t the command that I would use for the onkyo
utility. It should be system-power=query
homeassistant:/config# onkyo --host 10.1.1.71 system-power=query
unknown-model: system-power = on
homeassistant:/config# onkyo --host 10.1.1.71 system-power query
Error: Need at least command and argument
