Onkyo TX-NR7100 volume control
Hi
I’m having some trouble setting up a button to change the volume on my Onkyo receiver.
In the Developer tools Actions I’m able to change the volume with this yaml:
action: media_player.volume_down
  entity_id:
    - media_player.receiver
data: {}
But if I copy this into a button card, it no longer works.
type: custom:button-card
icon: mdi:volume-minus
tap_action: media_player.volume_down
  entity_id:
data: {}
I change action to tap_action to make it clickable.
I run Home assistant on bare metal (Dell Optiplex)
  • Core2024.8.2
  • Supervisor2024.08.0
  • Operating System13.0
  • Frontend20240809.0
Has anyone run into similar problems?
Tobbe
It (mostly) doesn’t go that way in button card… In this case your indentation (and some other things) is wrong.
Here’s my example:
tap_action:
  action: call-service
  service: media_player.volume_down
    entity_id: media_player.onkyo_receiver
Thank you, you solved it for me!
It works just like it is supposed to.
For anyone else looking for a solution that can repeatedly press the button while holding it down, this is my solution:
tap_action:
    entity_id: media_player.receiver
hold_action:
  repeat: 200
Tobbe
Yeah, i tried repeat action, but it’s hard to use on tablet or phone, since if you move finger a bit “hold” is immediately stopped, so you must really hold finger very still or it stops working quite quickly…
