Im new to HA, but I managed to install some items from HACS. Better weather module and configurable Light button…
Both work great on Windows lovelace, but on android they both give errors in their button box while defeult buttons work ok on android. … Why?
" Everything you find in HACS is not tested by Home Assistant, that includes HACS itself.
The HACS and Home Assistant teams do not support anything you find here."
I suppose it depends on the custom plugin you’re using but all of my custom front-end stuff works fine on my android phone.
Which one of you uses an SSL connection? I am curious if it has any correlation.
I use both internal (http) URL and Nabu Casa (https) URL depending on if I’m home or not if that’s what you are asking.
Everything works either way.
I had trouble with cards also when I was using http. But now I’m https only and no problem anymore. So I’m wondering if that has something to do with it.
I doubt it.
Like I said I use both and have no problems either way.
Which error?
Did you cleaned the cache on your phone?
Use the multitasking function on Android to actually close the Home Assistant app. Then when you open it again, it will be equivalent to refreshing the browser on Windows.
Post an issue on the custom card’s github.
When you make a change in frontend (importing new resource) you will get a notification to refresh lovelace cache to get latest changes.
this is less than helpful
Yes… I always refresh. I have 3 android tablet on each floor. All button settings work on chrome windows, but when I got to any tablet… they dont work there in app… =(
I havent tested it on tablet browser yet…
ERROR on tablets is : Custom element doesnt exist: light-entity-card
Strange… I also tried with android phone (note20)… button works great there!.. so what might this be??
Issue is ALL custom elements on android tablet. So problem seems to be HA Android APP…
how old is your andriod? Everything is working a-ok on my android device but I’m running the latest OS & browser.
all 3 tablets are 1 month old =) Brand new Lenovo android tablets with latest firmware on them and latest HA app
how have you included your resources?
? I dont understand question?
you have to include the resources when using them in the frontend. So how did you include the frontend resources?
