Only First action is triggered
I have an automation which is triggered by a telegram command. The command basically opens house door lock. But when I want to add other actions to the automation it only triggers the first action. Anyone have any idea ?
alias: Telegram  - Komut (202)
description: ''
  - platform: event
    event_type: telegram_command
    event_data:
      command: /202
condition: []
  - service: telegram_bot.send_message
    data_template:
      target: '{{ trigger.event.data.chat_id }}'
      message: Tamam {{ trigger.event.data["from_first"] }}, Hoşgeldin evimize!
  - type: turn_on
    device_id: 584c23e38e377e02a283a93483e10f32
    entity_id: switch.berko
    domain: switch
  - delay:
      hours: 0
      minutes: 0
      seconds: 2
      milliseconds: 0
  - type: turn_off
    domain: switch
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - service: alarm_control_panel.alarm_disarm
      code: '1234'
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - type: turn_on
    device_id: 6ad0743b163649ea99d9f3280103355f
    entity_id: switch.termosifon_socket
    domain: switch
mode: single
Are you getting any errors from your Telegram action? If so, try using the new Continue on error variable.
Nope. Whenever I perform the command (/door) it immediately opens the lock. But Right after that no action is taken. As ı can see it can onlu trigger first automation.
