Only ip is working with home assistant
After Home Assistant nuked itself I reinstalled it on my Pi 4. Since then, I can only access it through its IP address nothing else seems to work. Does anyone have any ideas on how to fix this? Any help would be appreciated
Have a look ing Settings > System > Network and check the host name is “homeassistant”. You should then be able to access it from “homeassistant:8123” or “homeassistant.local:8123”. What sort of HA install do you have - HAOS, Container, Core?
I changed the name of it and didn’t think that would affect it but I still can’t use my webpage to login duckdns. Also, I checked and my network setting and I did set the ip right. i also did whatever Raspberry Pi Imager dose
