Only one device tarcker showing up
I have put this section in my configuration.yaml
device_tracker:
  - platform: ping
    hosts:
      adrian_ping: 192.168.xxx.xxx
      karen_ping: 192.168.xxx.xxx
Checking config and all is OK. Problem is only the first device shows up. So either she has left me and I have been to busy playing with Home Assistant to notice :slight_smile: or I have written something wrong, can someone help?
I never actually knew you could do a device tracker by the IP address, good to know.
I’m guessing you need to separate them Into their own
- platform: ping
Yep tried that with no luck, I am just guessing its s imple typo I can’t see :slight_smile:
Is Karen’s device responding to ping outside of Home Assistant’s context? Depending on the device / operating system, ICMP Ping packages may be blocked.
Its not that it is not responding to the ping, it does that fine outside of home assistant its that “karen_ping” is not showing as an entity. in the entity list, or anywhere for that matter.
Hmm …
just tried it and entries pointing to a non-assigned IP result in missing device_tracker entities. Can you use the same IP for adrian and karen and check if device_tracker.karen_ping is available after restart?
Makes no sense, however - those devices should produce entities (that are ‘unavailable’ or ‘away’).
That looks like it, she is not here right now so her phone can’t be pinged. That stopped it showing as an entity. I tried it with the ip of my tablet and it worked, it didn’t work using the ip of my phone. Thanks problem solved wait till she comes home and see it it works then. Seems a bit daft for a home and away sensor to not set up if it can’t ping it when setting up.
Thanks again.
