I found out, that the diagnosis information of the TRVs are different.
The TRVs which don’t work, missing entries:
OK - “TRV Buro”:
NWK: 2dff = 11775
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.12.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.11.6",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "6.1.63-haos",
"supervisor": "2023.11.6",
"host_os": "Home Assistant OS 11.2",
"docker_version": "24.0.7",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"hacs": {
"version": "1.33.0",
"requirements": [
"aiogithubapi>=22.10.1"
"ble_monitor": {
"version": "12.6.3",
"requirements": [
"pycryptodomex>=3.18.0",
"janus>=1.0.0",
"aioblescan>=0.2.14",
"btsocket>=0.2.0",
"pyric>=0.1.6.3"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly",
"@TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"universal_silabs_flasher"
"requirements": [
"bellows==0.37.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.107",
"zigpy-deconz==0.22.0",
"zigpy==0.60.0",
"zigpy-xbee==0.20.0",
"zigpy-zigate==0.12.0",
"zigpy-znp==0.12.0",
"universal-silabs-flasher==0.0.15",
"pyserial-asyncio-fast==0.11"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 11775,
"manufacturer": "_TZE200_e9ba97vf",
"model": "TS0601",
"name": "_TZE200_e9ba97vf TS0601",
"quirk_applied": true,
"quirk_class": "zhaquirks.tuya.ts0601_trv.ZonnsmartTV01_ZG",
"quirk_id": null,
"manufacturer_code": 4098,
"power_source": "Battery or Unknown",
"lqi": 48,
"rssi": null,
"last_seen": "2023-12-13T13:05:09",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0301",
"input_clusters": [
"0x0000",
"0x0001",
"0x0004",
"0x0005",
"0x0006",
"0x000d",
"0x000f",
"0x0201",
"0x0204",
"0xef00"
"output_clusters": [
"0x000a",
"0x0019"
"2": {
"device_type": "0x0007",
"input_clusters": [
"0x0006",
"0x000d"
"output_clusters": []
"3": {
"input_clusters": [
"0x0006"
"model": "TS0601"
"active_coordinator": false,
"entities": [
"entity_id": "sensor.trv_buro_batterie_2",
"entity_id": "binary_sensor.trv_buro_binarer_eingang_2",
"entity_id": "number.trv_buro_nummer_opened_window_temperature_2",
"entity_id": "number.trv_buro_nummer_temperature_offset_2",
"entity_id": "switch.trv_buro_schalter_2",
"entity_id": "switch.trv_buro_schalter_3",
"entity_id": "climate.trv_buro_thermostat_2",
"entity_id": "switch.trv_buro_schalter_1",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "THERMOSTAT"
"name": "COMBINED_INTERFACE"
"user_given_name": "TRV B\u00fcro",
"device_reg_id": "21c06d5b4da6f22aaa8beb2107736a04",
"area_id": "buro",
"cluster_details": {
"1": {
"device_type": {
"name": "THERMOSTAT",
"id": 769
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {},
"unsupported_attributes": {}
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x0000": {
"0x4003": {
"attribute_name": "start_up_on_off"
"0xef00": {
"endpoint_attribute": "tuya_manufacturer",
"attributes": {
"0x0223": {
"attribute_name": "battery",
"value": 100
"0x0265": {
"attribute_name": "boost_duration_seconds",
"value": 0
"0x0128": {
"attribute_name": "child_lock",
"value": 0
"0x0268": {
"attribute_name": "comfort_mode_temperature",
"value": 220
"0x0269": {
"attribute_name": "eco_mode_temperature",
"value": 180
"0x052d": {
"attribute_name": "fault_detected",
"value": 0
"0x010a": {
"attribute_name": "frost_protection",
"value": 0
"0x016b": {
"attribute_name": "heating_stop",
"value": 0
"0x0220": {
"attribute_name": "holiday_temperature",
"value": 170
"0x0402": {
"attribute_name": "mode",
"value": 1
"0x0473": {
"attribute_name": "online",
"value": 1
"0x0173": {
"attribute_name": "online_set",
"value": 0
"0x0266": {
"attribute_name": "opened_window_temperature",
"value": 140
"0x0210": {
"attribute_name": "target_temperature",
"value": 200
"0x0218": {
"attribute_name": "temperature",
"value": 208
"0x021b": {
"attribute_name": "temperature_calibration",
"value": 0
"0x041f": {
"attribute_name": "week_format",
"value": 0
"0x0108": {
"attribute_name": "window_detection",
"value": 0
"0x000d": {
"endpoint_attribute": "analog_output",
"attributes": {
"0x0100": {
"attribute_name": "application_type",
"value": 9
"0x001c": {
"attribute_name": "description",
"value": "Temperature Offset"
"0x0075": {
"attribute_name": "engineering_units",
"value": 62
"0x0041": {
"attribute_name": "max_present_value",
"value": 5
"0x0045": {
"attribute_name": "min_present_value",
"value": -5
"0x0055": {
"attribute_name": "present_value",
"value": 0.0
"0x006a": {
"attribute_name": "resolution",
"value": 0.1
"0x0068": {
"attribute_name": "relinquish_default"
"0x0055": {
"0x0201": {
"endpoint_attribute": "thermostat",
"attributes": {
"0x001d": {
"attribute_name": "alarm_mask",
"value": 0
"0x001b": {
"attribute_name": "ctrl_sequence_of_oper",
"value": 2
"0x0000": {
"attribute_name": "local_temperature",
"value": 2080
"0x0010": {
"attribute_name": "local_temperature_calibration",
"value": 0
"0x0016": {
"attribute_name": "max_heat_setpoint_limit",
"value": 3000
"0x0015": {
"attribute_name": "min_heat_setpoint_limit",
"value": 500
"0x0012": {
"attribute_name": "occupied_heating_setpoint",
"value": 2000
"0x4002": {
"attribute_name": "operation_preset",
"value": 1
"0x0025": {
"attribute_name": "programing_oper_mode",
"value": 0
"0x001e": {
"attribute_name": "running_mode",
"value": 0
"0x0029": {
"attribute_name": "running_state",
"value": 0
"0x001c": {
"attribute_name": "system_mode",
"value": 4
"0x0014": {
"attribute_name": "unoccupied_heating_setpoint",
"value": 1700
"0x0000": {
"0x0006": {
"attribute_name": "abs_max_cool_setpoint_limit"
"0x0003": {
"attribute_name": "abs_min_heat_setpoint_limit"
"0x0004": {
"attribute_name": "abs_max_heat_setpoint_limit"
"0x0005": {
"attribute_name": "abs_min_cool_setpoint_limit"
"0x0018": {
"attribute_name": "max_cool_setpoint_limit"
"0x0002": {
"attribute_name": "occupancy"
"0x0007": {
"attribute_name": "pi_cooling_demand"
"0x0008": {
"attribute_name": "pi_heating_demand"
"0x0017": {
"attribute_name": "min_cool_setpoint_limit"
"0x0011": {
"attribute_name": "occupied_cooling_setpoint"
"0x0012": {
"0x0013": {
"attribute_name": "unoccupied_cooling_setpoint"
"0x0014": {
"0x001e": {
"0x001c": {
"0x0029": {
"0x0204": {
"endpoint_attribute": "thermostat_ui",
"attributes": {
"0x0001": {
"attribute_name": "keypad_lockout",
"value": 0
"0x000f": {
"endpoint_attribute": "binary_input",
"attributes": {
"0x001c": {
"value": "Open Window Detected"
"0x0055": {
"value": 0
"0x0055": {
"0x0001": {
"endpoint_attribute": "power",
"attributes": {
"0x0021": {
"attribute_name": "battery_percentage_remaining",
"value": 200
"0x0033": {
"attribute_name": "battery_quantity",
"value": 2
"0x0034": {
"attribute_name": "battery_rated_voltage",
"value": 15
"0x0031": {
"attribute_name": "battery_size",
"value": 3
"0x0020": {
"attribute_name": "battery_voltage"
"0x0021": {
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"2": {
"device_type": {
"name": "COMBINED_INTERFACE",
"id": 7
"profile_id": 260,
"in_clusters": {
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x0000": {
"0x4003": {
"0x000d": {
"attributes": {
"0x0100": {
"value": 0
"0x001c": {
"value": "Opened Window Temperature"
"0x0075": {
"value": 62
"0x0041": {
"value": 30.0
"0x0045": {
"value": 5.0
"0x0055": {
"value": 14.0
"0x006a": {
"value": 0.5
"0x0068": {
"0x0055": {
"out_clusters": {}
"3": {
"device_type": {
"id": 7
"profile_id": 260,
"in_clusters": {
"0x0006": {
"attributes": {
"0x0000": {
"value": 1
"0x0000": {
"0x4003": {
"out_clusters": {}
