Hi guys, could you please help me setting up the process below?
I will use 2 Sonoff POW 16A to power two different circuits. Both of them are flashed with tasmota.
I need to configure them in such a way that there is no possibility that both of them will be turned on at the same time. The following rules apply:
- If someone turns on #1, #2 automatically turns off.
- If someone turns on #2, #1 automatically turns off.
- If both are turned off, #1 automatically turns on (at least one got to be turned on).
- In case of a power outage, both of them come back obbeying the last power state.
I want to avoid as much as possible that both circuits become activated at the same time, even if it is for a fraction of time.
I am trying to implement something similar to a “selector switch”.
How would you guys do that?
Thank you!
