Only report sensor data based on binairy sensor home assistant
I have 2 DS18B20’s connected to the central heating supply and return pipes next to my boiler. I want to monitor te temps and calculate the delta T between the supply and return.
These values and delta T are only needed when the boiler is running. when the boiler is not busy these temps are not valuable and not neede to be reported to Home Assistant.
I have a binary sensor from my openTherm integration that states the boiler is running.
Can someone elaborate how i can import the home assistant binary sensor in esphome and use that as condition to report the temps?
esphome:
  friendly_name: Central heating temperatures
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "SoMw20UjV81pgTZG3rgHBFyyTsxfJxDUi9ZhcPacULw="
ota:
  - platform: esphome
    password: "7e36b4cb54e9ee107c7666cdd7cb9abe"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.188.138
    gateway: 192.168.188.1
    subnet: 255.255.255.0
  ap:
    ssid: "ch_temp Fallback Hotspot"
    password: "8aeGdhZw8vFO"
captive_portal:
one_wire:
  - platform: gpio
    pin: GPIO2
    # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    name: ch_temp WiFi Signal
    update_interval: 120s
  - platform: dallas_temp
    address: 0x760823c09876fe28
    update_interval: 20s
    unit_of_measurement: "°C"
    icon: "mdi:thermometer-chevron-up"
    device_class: "temperature"
    state_class: "measurement"
    accuracy_decimals: 4
    filters:
      - delta: 0.01
    address: 0x1a0623c310999128
    icon: "mdi:thermometer-chevron-down"
    filters:
      - delta: 0.01
