I created a simple test script via the web interface. I can edit / run this script via the web interface, however, when I save the script it returns to the device page and shows the script, however, when I click on the script I get a dialogue box with “Only scripts inside scripts.yaml are editable.”
HA is running inside a docker on my NAS and is reporting
Home Assistant 2022.12.9
Frontend 20221213.1 - latest
If I navigate to the homeassistant config folder on the NAS then I can see and open scripts.yaml and the content reflects the script I created, however, as I’m still learning about HA, I’d rather use the supplied GUI rather than hand crafting scripts for a while.
If I delete a script from the yaml file and then reload the config, the script is gone in the front-end, but the remaining tests are still un-editable.
Any suggestions on how to resolve would be much appreciated
