Hi there,
ist there any possibility to show just the state of a switch in an entity-card?
thanks and regards
BJ70
Hi there,
thanks and regards
BJ70
Wrap it in a template sensor and display that.
How should Info that?
I have no skills in doing templates
If it doesn’t necessarily have to be a Entity Card, chose a Button Card and block the action functions.
What card do you want to use? The normal entity card will only show the state:
type: entity
entity: switch.my_switch
If you use an entities
card, you can show the state instead of the toggle by using type: simple-entity
type: entities
entities:
- entity: switch.my_switch
type: 'simple-entity'
