ONVIF and RTSP camera works in VLC but not in Home Assistant
I’m trying to add this kind of IP camera to my HA instance running on an RPI3 with HASSIO, and I just can’t manage to do it. It’s accessible in VLC at rtsp://USER:[email protected]:554/ch0_0.h264 (and a bunch of other addresses I’ve found in different places), but none of it works in HA.
As you may be able to tell, I’m a complete noob with cameras and non-straight forward integrations in general, so I wouldn’t be surprised if I’ve made any obvious mistakes.
This is my config right now:
stream:
ffmpeg:
  ffmpeg_bin: /usr/bin/ffmpeg
camera:
  - platform: ffmpeg
    name: "IPC 360 Camera ffmpeg"
    input: -rtsp_transport tcp -i rtsp://USER:[email protected]:554/ch0_0.h264
  - platform: mjpeg
    name: "IPC 360 Camera mjpeg"
    mjpeg_url: rtsp://USER:[email protected]:554/cam/realmonitor
  - platform: generic
    name: IPC 360 Camera generic
    still_image_url: http://10.0.1.xx/snapshot.jpg?user=USER&pwd=PASSWORD
    stream_source: rtsp://10.0.1.xx:554/live/ch0
    verify_ssl: false
    authentication: basic
    username: USER
    password: PASSWORD
As I said, all of the addresses work in vlc. I doubt the generic platform will ever be an option, as I actually don’t have a still_image_url, so that’s just sheer desperation from my side. I only have one of these in use right now, but I’ve tried all kinds of different combinations.
I also tried adding the camera via the ONVIF integration, and while the different profiles show up, there is no image.
Anyway, these are all the logs I get:
WARNING (MainThread) [homeassistant.components.onvif] The date/time on the device (UTC) is '2021-02-26 12:58:19+00:00', which is different from the system '2021-02-26 11:58:20.742318+00:00', this could lead to authentication issues
ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream "rtsp://USER:[email protected]:554/ch0_0.h264"
And then the last row just repeats itself every time I try to open one of the camera entities, with whatever url I’m using for that particular integration. This also applies for the ONVIF integration devices.
I tried to include every bit of information I thought of, but if I’ve missed anything, please let me know. I know there are hundreds of conversations with very similar problems, but I feel like I’ve seen every single one of them and tried everything, and I still can’t get it to work, so I’m very thankful for any and all help.
Could you try this?
- platform: ffmpeg
Doesn’t work.
I just noticed I also get this error after HA restart:
2021-02-27 11:48:49 WARNING (MainThread) [homeassistant.components.onvif] The date/time on the device (UTC) is '2021-02-27 11:48:47+00:00', which is different from the system '2021-02-27 10:48:47.444457+00:00', this could lead to authentication issues
So HA has the wrong time? How do I change that?
To be clear, the first time, “2021-02-27 11:48:49”, is correct. And the time the “device” has. The “system” then says a different time.
Edit: Yep, this was actually the problem. I couldn’t find how to change the (internal?) time in HA, but I was able to change the camera time in ONVIF on my pc. After that, it worked.
