ONVIF camera not connecting?
Anyone know how to fix this? My onvif camera isnt being displayed in ha… the password and username and port are correct, its just not working… see the attached screenshot… any ideas?
Gershy13
onvif
have you installed ffmpeg?
What can you see in your logs?
im running hassio? do i still have to install it? if so how? Ive added the ffmpeg: to my config file. and no the logs dont seem to point out any errors…
not sure if FFMPEG is installed with hass.io. To check SSH to it and type ffmpeg -version
If you get an error, you’ll have to install it.
this is what the home assistant component for ffmpeg says/
If you are using Hass.io then just move forward to the configuration as all requirements are already fulfilled.
Im not sure how to SSH into hassio.
ok, can you share your config please?
Sorry for the late reply, didn’t realise I had a notification… How would I share my config?
copy paste the part where you define your camera. Make sure you use the </> button to format your code
camera:
  • platform: onvif
    host: 192.168.0.42
    username: admin
    password: *******
    port: 8001
