Hi, I try setting up an onvif camera. The setup succeeds, but no entity is created. I get the following error in de log.
2020-06-05 18:52:58 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Oprit - 00:82:4C:69:39:17 for onvif
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/config_entries.py”, line 217, in async_setup
hass, self
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/onvif/init.py”, line 83, in async_setup_entry
if device.capabilities.events and await device.events.async_start():
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/onvif/event.py”, line 77, in async_start
await pullpoint.SetSynchronizationPoint()
File “/srv/homeassistant/lib/python3.7/site-packages/zeep/asyncio/bindings.py”, line 20, in send
return self.process_reply(client, operation_obj, response)
File “/srv/homeassistant/lib/python3.7/site-packages/zeep/wsdl/bindings/soap.py”, line 195, in process_reply
return self.process_error(doc, operation)
File “/srv/homeassistant/lib/python3.7/site-packages/zeep/wsdl/bindings/soap.py”, line 362, in process_error
subcodes=subcodes,
zeep.exceptions.Fault: Method ‘ns0:SetSynchronizationPoint’ not implemented: method name or namespace not recognized
Before the integration, the camera worked fine with the following configuration:
- platform: onvif
host: 192.168.2.72
username: admin
password: ****
port: 80
profile: 1
