Hi there!
I have been using Home Assistant for quite a while and I have both relative expensive cameras (from Dahua and Hikvision) and extremely cheap cameras.
All of them are Onvif compatible cameras, but the thing is that Dahua / Hikvision pay for a certain ONVIF profile, so that it can register motion detect in a NVR, and the cheap chinese cameras do not…
BUT…
And this is the part I want to share with you, is that Hiseeu cameras appear to have their own motion detect, that is recognised by home assistant as an entity “binary_sensor.mymotiondetectorrule_cell_motion_detection”, with the help of the ONVIF integration.
So now I got it to work that I get a message and a picture on Telegram whenever someone is at the gate. Exactly what I was looking for.
I can conform that it works with the HB615 and the HB613
I bought them on Banggood for around 30 USD
So if you are looking for a very cheap camera with motion detect, POE support, nightvision, sound and 3/5 Megapixels, I could recommend this one!
Negative things:
- A little black plastic strip (not sure what it does) had to be glued on. It fell off when I took it out of the box. Wrong kind of glue maybe? Easily fixed though!
- One of the five I bought got problems with moist on the inside after a few months of use. Maybe a “monday morning-product”?
