sytchi
(Sytchi)
March 20, 2020, 9:25pm
1
Hi!
I updated today my installation to 0.107.2. Unfortunately that broke my cams configuration. I have several cameras on one DVR integrated through onvif. Thats my config for that:
camera:
- platform: onvif
host: 192.168.1.13
username: *****
password: *****
profile: 1
port: 80
- platform: onvif
host: 192.168.1.13
username: *****
password: *****
profile: 0
port: 80
For each camera all the config is the same apart the profile number.
That configuration used to work in 0.105 and now it tries to assign the same entity_id to all the cameras.
2020-03-20 21:57:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 425, in _async_add_entity
raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: camera.entarnance. Platform onvif does not generate unique IDs
How can I fix that?
olijouve
(olivyeah)
March 21, 2020, 9:46am
3
I havenāt touched to entity creation in my ONVIF PR embedded in this release, only altered ptz service.
So it could be relative to other parent camera change or even maybe to that issue :
https://github.com/home-assistant/core/issues/32992
xes
March 21, 2020, 11:04am
4
Same issue for me but not related to the bug https://github.com/home-assistant/core/issues/32992 because I didnāt overrided the docker command. For my part, I sue docker-compose on Synology.
xes
March 21, 2020, 11:39am
5
Ok, seems there is an issue if you set 2 times the same onvif camera with 2 differents profilesā¦ (Maybe we can also have this issue with 2 differents onvif camera??)
My workaround is to use generic camera while waiting for a fix.
sytchi
(Sytchi)
March 21, 2020, 12:21pm
6
How do you reverse engineer the stream address from ONVIF? I found a tool for windows to do that, but I donāt have windows on any machineā¦
BTW.: Created an issue for the problem:
olijouve
(olivyeah)
March 21, 2020, 1:11pm
7
Enable debug logging for Onvif and all related as i donāt remeber which one provides this info:
homeassistant.components.onvif.camera: debug
homeassistant.components.camera: debug
zeep.asyncio.transport: debug
zeep.asyncio: debug
Restart HA then look at your logs for āONVIF Camera Using the following URL for ā¦ā string, it should include your RTSP URI.
xes
March 21, 2020, 2:10pm
8
Thanks for your reply
rtsp://<user>:<password>@192.168.0.90:554/12
Just tested the 0.107.4 version and the issue still occurs
Partial Logs (Removed soap xml lines because message was too big to be posted here):
2020-03-21 15:03:44 INFO (MainThread) [homeassistant.components.camera] Setting up camera.generic
2020-03-21 15:03:44 INFO (MainThread) [homeassistant.components.camera] Setting up camera.onvif
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera platform
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Constructing the ONVIFHassCamera
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Importing dependencies
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera component
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera device @ '192.168.0.90:8080'
2020-03-21 15:03:44 DEBUG (MainThread) [homeassistant.components.onvif.camera] Updating service addresses
2020-03-21 15:03:45 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/device_service:
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera platform
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Constructing the ONVIFHassCamera
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Importing dependencies
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera component
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF camera device @ '192.168.0.90:8080'
2020-03-21 15:03:45 DEBUG (MainThread) [homeassistant.components.onvif.camera] Updating service addresses
2020-03-21 15:03:46 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/device_service:
2020-03-21 15:03:46 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/device_service (status: 200):
2020-03-21 15:03:46 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/event_service:
2020-03-21 15:03:46 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/event_service (status: 400):
2020-03-21 15:03:47 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/device_service:
2020-03-21 15:03:47 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/event_service (status: 400):
2020-03-21 15:03:47 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/device_service (status: 200):
2020-03-21 15:03:47 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF device management service
2020-03-21 15:03:48 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving current camera date/time
2020-03-21 15:03:48 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/device_service:
2020-03-21 15:03:48 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/device_service (status: 200):
2020-03-21 15:03:48 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF device management service
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving current camera date/time
2020-03-21 15:03:49 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/device_service:
2020-03-21 15:03:49 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/device_service (status: 200):
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] TimeZone for date/time: UTC
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] Camera date/time: 2020-03-21 14:03:49+00:00
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] Camera date/time in UTC: 2020-03-21 14:03:49+00:00
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] System date/time: 2020-03-21 14:03:48.775385+00:00
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] Connecting with ONVIF Camera: 192.168.0.90 on port 8080
2020-03-21 15:03:49 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving profiles
2020-03-21 15:03:50 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/media_service:
2020-03-21 15:03:50 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/device_service (status: 200):
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] TimeZone for date/time: UTC
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Camera date/time: 2020-03-21 14:03:49+00:00
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Camera date/time in UTC: 2020-03-21 14:03:49+00:00
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] System date/time: 2020-03-21 14:03:49.408647+00:00
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Connecting with ONVIF Camera: 192.168.0.90 on port 8080
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving profiles
2020-03-21 15:03:50 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/media_service (status: 200):
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieved '2' profiles
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Using profile index '0'
2020-03-21 15:03:50 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving stream uri
2020-03-21 15:03:51 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/media_service:
2020-03-21 15:03:51 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/media_service (status: 200):
2020-03-21 15:03:51 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieved '2' profiles
2020-03-21 15:03:51 DEBUG (MainThread) [homeassistant.components.onvif.camera] Using profile index '1'
2020-03-21 15:03:51 DEBUG (MainThread) [homeassistant.components.onvif.camera] Retrieving stream uri
2020-03-21 15:03:52 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Post to http://192.168.0.90:8080/onvif/media_service:
2020-03-21 15:03:52 DEBUG (MainThread) [zeep.asyncio.transport] HTTP Response from http://192.168.0.90:8080/onvif/media_service (status: 200):
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] ONVIF Camera Using the following URL for camera_entree: rtsp://<user>:<password>@192.168.0.90:554/11
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] Setting up the ONVIF PTZ service
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] PTZ is not available
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] Completed set up of the ONVIF camera component
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] Camera 'camera_entree' added to hass
2020-03-21 15:03:52 DEBUG (MainThread) [homeassistant.components.onvif.camera] ONVIF Camera Using the following URL for camera_entree_profile1: rtsp://<user>:<password>@192.168.0.90:554/12
2020-03-21 15:03:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
homeassistant.exceptions.HomeAssistantError: Entity id already exists: camera.camera_entree_profile1. Platform onvif does not generate unique IDs
I have also noticed the same since 0.107.0, I had two streams for the same camera as two different entities (one low quality and one high, profile 0 and profile 1) and worked just fine on 0.106.X but now it complains that is a duplicate
xes
March 21, 2020, 2:19pm
10
Probably relative to the code change of the 2020 february the 22th:
committed 09:29PM - 22 Feb 20 UTC
@property
def unique_id(self) -> Optional[str]:
"""Return a unique ID."""
return self._mac
async def async_obtain_mac_address(self):
"""Obtain the MAC address of the camera to use as the unique ID."""
devicemgmt = self._camera.create_devicemgmt_service()
network_interfaces = await devicemgmt.GetNetworkInterfaces()
for interface in network_interfaces:
if interface.Enabled:
self._mac = interface.Info.HwAddress
The unique Id seems to be generated from the hardware mac addressā¦
xes
March 21, 2020, 2:46pm
11
sytchi
(Sytchi)
March 21, 2020, 5:52pm
12
Bug was already linked 5h earlier
Relevant PR to watch:
home-assistant:dev
ā home-assistant:frenck-2020-0319
opened 03:22PM - 21 Mar 20 UTC
