Onvif Cameras
Hi! What happened to the tests? thank! :slight_smile:
Hey there! Proper devicemgmt.wsdl file helped me with ā€œONVIFError: Unknown error: (400, ā€˜Bad Requestā€™)ā€ error on my Chinese cameras. Ensure that you have set of .wsdl files in both of /etc/onvif/wsdl and /path_to_your_virtualenv/lib/python3.5/site-packages/onvif/wsdl locations. Your can download them from ONVIF site https://www.onvif.org/profiles/specifications/ or somewhere else :slight_smile:
I have hassio and i donā€™t have of these files or directories , should i create them?
Iā€™m not sure about hass.io but .wsdl files should be present in /etc/onvif/wsdl at least.
im using the latest version of hass.io and there is no such folder /etc/onvif let alone /etc/onvif/wsdl
Just create it!
I tried to insert the file in the hass.io folders ā€¦ but the error remains! other tips? solutions? the cam works correctly with all the onvif apps !!!
Iā€™ve got cams only pan and tilt (not zoom)
With onvifer on Android or onvif manager on Windows I can rotate them perfectly but ha keep saying ā€œcameras does not support ptzā€
I think the component onvif needs some tweaking.
