Onvif Cameras
Hi, i have some chinese camera with onvif support, im using onvifier on my phone and its working great, im also using it iSpy and CyeWeb and i have no issue
Im trying to get it work with Home-Assistant but with no luck
Im using ONVIF Device Manager to configure my camera
ffmpeg:
camera:
  - platform: onvif
    host: 172.16.82.81
    port: 8899
    username: homeassistant
    password: mypassword
Pastebin: Log
How did you come up with that configuration?
I was editing my post right now my onvif port is 8899
I was able to get it work with the ffmpeg component but its not live feed
camera:
  - platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://172.16.82.81:554/user=admin_password=L2y82hQT_channel=1_stream=0.sdp?real_stream
Should probably be something like:
camera:
  - platform: onvif
    host: 172.16.82.81
    port: 8899
If you look at my first post this is exacly my config, i posted my log on pastebin:
Pastebin: Log
“ONVIFError: Unknown error: (400, ‘Bad Request’)”
The login credentials is most likely different for the Onvif stream.
Maybe admin/admin
I tried but i have the same error, i also created a new user just for home assistant
I also check my onvif port on my device:
Did you try using
What is image “Onvif cheque” You may need to enable it?
When I did my printscreen a few minutes ago I thought the same thing, after activating the option Onvifier application on my phone stop working and the camera was no longer detected in Onvif Device Manager.
I tried the option Generic IP Camera but it gives me an image each 10 seconds, I do not have the video in real time
That’s normal, the card won’t display live video, but refresh image every 10 sec?, I think, once you click on the card the window should open up with a faster stream.
When I click the card I only see a timeline of camera activity, I watched youtube video and saw camera setup with real time feed, It’s probably another type of camera that is supported, I saw that there was a ZoneMinder module, I could make a VM and added my cameras to see if I can connect them
In Homeassistant?
Look at this beautiful dashboard, you can see at 0:28 live feed video
Dashboard
Like this:image
Or this: image
Hadashboard is a whole different story.
What are you using to record you cameras?
My bad if i click the camera card and wait like 5 sec i have a live low quality feed refresh 1sec
Im recording my feed with iSpy on a virtual machine i was using CyeWeb in the past with no issue
Either way, I think the end result would be the same.
See this post: Hikvision setup
This is very well explained in the topic you sent me, I will try with the mjpeg module
I will try tomorrow because it is late, thank you for your help and your valuable advice!
I will update my post tomorrow if it works!
:+1:Cheers!
