Hi!
I added my camera HIKVISION IPC-C082-G2 to home assistant via ONVIF integration
I see the static image from it but can’t open stream.
There is an error in log when I tryed to open stream:
Logger: homeassistant.components.stream.stream.camera.hall_mainstream
Source: components/stream/__init__.py:347
Integration: Stream ([documentation](https://www.home-assistant.io/integrations/stream), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+stream%22))
First occurred: 15:19:35 (10 occurrences)
Last logged: 15:27:05
Error from stream worker: Error opening stream (ERRORTYPE_5, Input/output error) rtsp://****:****@192.168.7.29:554/Streaming/Channels/101?transportmode=unicast&profile=Profile_1
How to resolve it?
