Onvif FDT IP Cameras and Amcrest integration not working in HASSIO V 0.64.0 [haffmpeg.core] FFmpeg isn't running!
I’ve been able to rid myself of most of the errors I was receiving but I can’t seem to find a solution for this one. I have 8 FDT cameras around my home and I’m only playing with one of them for the moment. my config.yaml has this
ffmpeg:
# Cameras
camera:
  platform: onvif
  host: 192.168.x.yy
  port: 8080
  username: admin
  password: xxxx
All of my cameras are working through the AMCREST monitioring NVR and the setup for this particular camera is:
onvif%20params
When I launch Home Assistant I now get a camera block without an image
But when I click on the image nothing happens. The log file only reports the following:
2018-02-27 10:06:35 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
Is there something that I’m not doing with the ffmpeg setup? According to the documentation i don’t see any additional parameters needed for this component.
Interested too
Well, I’m getting a little farther. Running HASSIO 0.72. I had the wrong port in configuration.yaml. I’m getting a response the camera is connecting…then it crashes. but here is the error log:
2018-07-12 19:37:44 DEBUG (SyncWorker_8) [homeassistant.components.camera.onvif] Connecting with ONVIF Camera: 192.168.8.41 on port 8080
2018-07-12 19:37:46 DEBUG (SyncWorker_4) [homeassistant.components.camera.onvif] Connecting with ONVIF Camera: 192.168.8.41 on port 8080
2018-07-12 19:37:48 DEBUG (SyncWorker_8) [homeassistant.components.camera.onvif] ONVIF Camera Using the following URL for Cam-Kitchen: rtsp://:@192.168.8.41:554/11
2018-07-12 19:37:48 DEBUG (SyncWorker_4) [homeassistant.components.camera.onvif] ONVIF Camera Using the following URL for Cam-Kitchen: rtsp://:@192.168.8.41:554/11
2018-07-12 19:39:12 ERROR (SyncWorker_2) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-07-12 19:39:56 ERROR (MainThread) [aiohttp.server] Unhandled exception
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 398, in start
await resp.prepare(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_response.py”, line 300, in prepare
return await self._start(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_response.py”, line 605, in _start
return await super()._start(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_response.py”, line 367, in _start
await writer.write_headers(status_line, headers)
File “/usr/lib/python3.6/site-packages/aiohttp/http_writer.py”, line 100, in write_headers
self._write(buf)
File “/usr/lib/python3.6/site-packages/aiohttp/http_writer.py”, line 57, in _write
raise ConnectionResetError(‘Cannot write to closing transport’)
ConnectionResetError: Cannot write to closing transport
How far are you with this? Any chance you could help me at least figure out how to propperly set up the logging feature to only display errors comming out of the onvif part?
Just put this in your configuration.yaml file and uncomment the logging you want
logger:
  default: warning
  logs:
#    homeassistant.components.mqtt: debug
#    homeassistant.components.camera: debug
#    custom_components.camera.onvif: debug
I am considering buying an Amcrest NVR for my SV3C Cameras, but your post has me worried. Will I not be able to pull the Camera feed into HA via Amcrest?
I haven’t been able to get it to work yet.
