Onvif integration HTTPS
Just trying the new Onvif integration, but when i try to connect to my NVR i get:
zeep.exceptions.Fault: The ONVIF client may not support HTTPS mode. Please check the client settings or disable HTTPS in the Device configuration settings and try again. If the problem persists, contact technical support.
The NVR is running HTTPS with a selfsigned certificate, which i guess cause the error, so how do i add this as a thrusted certificate?
Running 110.1 in windows hyper-v HassOS 3.13
Anyone knows how to add selfsigned certificates to thrusted on HA?
