Onvif integration with empty password
Hello I have a Digoo webcam model DG-BM01 720p and I am trying to configuration via the new integration in 0.110.1
I believe that for the the onvif protocol it it using port 80 rather than 5000 and is not using any password.
The integration won’t let me submit if no password is entered.
any idea?
Not sure if it helps or if I should report it as a bug but when I try to enter a password (in my case password) I get the following backtrace
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 552, in write_bytes
    await self.body.write(writer)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/payload.py", line 231, in write
    await writer.write(self._value)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 101, in write
    self._write(chunk)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 67, in _write
    raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 125, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 145, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 54, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 103, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 170, in async_step_auth
    return await self.async_step_profiles()
  File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 201, in async_step_profiles
    network_interfaces = await devicemgmt.GetNetworkInterfaces()
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/bindings.py", line 13, in send
    options["address"], envelope, http_headers
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 107, in post_xml
    response = await self.post(address, message, headers)
  File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 95, in post
    proxy=self.proxy,
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 504, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 847, in start
    message, payload = await self._protocol.read()  # type: ignore  # noqa
  File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 591, in read
    await self._waiter
aiohttp.client_exceptions.ClientOSError: [Errno None] Can not write request body for http://192.168.0.207:80/onvif/device_service
Hi
I have the same problem, I have a Chinese camera, when I integrate the camera into ispy I don’t enter the user and password (if I enter it it won’t connect), it’s the same on HA, the integration itself finds the camera but wants to enter the user and password after me but when there I will enter something so write the error “with this user and password cannot be connected”. For this to work, I need to enter an “empty” password and user.
any idea how she did it?
or fix in the next version of HA?
Actually I had not noticed but now you can enter submit with no password (at least with version 0.110.4)
But I still get the crash that I mention above.
I have never written a bug report towards HA so not sure where to start. If that is a bug that is!
I noticed that it is not necessary to enter the password, but it is necessary for me not to have to enter the user, otherwise it does not work for me. But I think it’s not a mistake, this function was given there so that people do not forget to enter the login details, but probably do not expect that some campers require you to enter nothing.
Now I have found in ispy that I can enter anything in the password field and the camera will connect. But if I enter something into the user, it is not possible to connect.
