I’m unable to get Onvif up an running with a DAHUA IPC-HDBW4431R-ZS, I’m keep getting the following error:
2017-08-21 20:47:52 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform onvif
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/onvif/client.py", line 34, in wrapped
return func(*args, **kwargs)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/onvif/client.py", line 201, in wrapped
return call(params, callback)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/onvif/client.py", line 191, in call
ret = func(**params)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/client.py", line 559, in __call__
return client.invoke(args, kwargs)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/client.py", line 618, in invoke
result = self.send(soapenv)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/client.py", line 652, in send
reply = transport.send(request)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/transport/http.py", line 178, in send
return HttpTransport.send(self, request)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/transport/http.py", line 78, in send
fp = self.u2open(u2request)
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/suds/transport/http.py", line 119, in u2open
return url.open(u2request, timeout=tm)
File "/usr/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/usr/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/usr/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/lib/python3.6/urllib/request.py", line 1346, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.6/urllib/request.py", line 1321, in do_open
r = h.getresponse()
File "/usr/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.6/http/client.py", line 266, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
res = func(*args, **kw)
File "/usr/lib/python3.6/site-packages/homeassistant/components/camera/onvif.py", line 49, in async_setup_platform
async_add_devices([ONVIFCamera(hass, config)])
File "/usr/lib/python3.6/site-packages/homeassistant/components/camera/onvif.py", line 70, in __init__
self._input = media.GetStreamUri().Uri
File "/srv/docker/config/home-assistant/deps/lib/python3.6/site-packages/onvif/client.py", line 36, in wrapped
raise ONVIFError(err)
onvif.exceptions.ONVIFError: Unknown error: Remote end closed connection without response
Configuration:
camera:
- platform: onvif
host: 192.168.0.115
username: "admin"
password: "PASS"
ffmpeg:
I have tried different ports, here are the ports configuration:
I’m missing something?
