Sorry for my english. I just bought an onvif camera. It works perfectly in other systems I have integrated it with, but using integration in homeassistant I get this error.
Logger: homeassistant.config_entries
Source: components/onvif/event.py:154
First occurred: 22:36:58 (1 occurrences)
Last logged: 22:36:58
Error setting up entry ONVIF_CAMERA - 44:01:bb:a8:75:be for onvif
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 249, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/onvif/__init__.py", line 74, in async_setup_entry
if not await device.async_setup():
File "/usr/src/homeassistant/homeassistant/components/onvif/device.py", line 107, in async_setup
self.capabilities = await self.async_get_capabilities()
File "/usr/src/homeassistant/homeassistant/components/onvif/device.py", line 252, in async_get_capabilities
pullpoint = await self.events.async_start()
File "/usr/src/homeassistant/homeassistant/components/onvif/event.py", line 86, in async_start
await self.async_renew()
File "/usr/src/homeassistant/homeassistant/components/onvif/event.py", line 154, in async_renew
await self._subscription.Renew(termination_time)
File "/usr/local/lib/python3.8/site-packages/zeep/proxy.py", line 64, in __call__
return await self._proxy._binding.send_async(
File "/usr/local/lib/python3.8/site-packages/zeep/wsdl/bindings/soap.py", line 164, in send_async
return self.process_reply(client, operation_obj, response)
File "/usr/local/lib/python3.8/site-packages/zeep/wsdl/bindings/soap.py", line 229, in process_reply
return self.process_error(doc, operation)
File "/usr/local/lib/python3.8/site-packages/zeep/wsdl/bindings/soap.py", line 381, in process_error
subcode_qname = as_qname(
File "/usr/local/lib/python3.8/site-packages/zeep/utils.py", line 36, in as_qname
raise XMLParseError("No namespace defined for %r (%r)" % (prefix, value))
zeep.exceptions.XMLParseError: No namespace defined for 'wsrf-rw' ('wsrf-rw:ResourceUnknownFault')
