I have an Eminent E6330 camera which I try to setup through onvif, but it doesn’t work.
In my camera back-end, onvif is activated:
But the onvif setup doesn’t detect it and manual input gives “unknown error”
Tried multiple ports (including 80 & 443), but no luck
Logger: aiohttp.server
Source: components/onvif/config_flow.py:203
First occurred: 13:40:09 (1 occurrences)
Last logged: 13:40:09
Error handling request
File "/usr/local/lib/python3.8/site-packages/httpx/_transports/default.py", line 61, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.8/site-packages/httpx/_transports/default.py", line 277, in handle_async_request
) = await self._pool.handle_async_request(
File "/usr/local/lib/python3.8/site-packages/httpcore/_async/connection_pool.py", line 230, in handle_async_request
response = await connection.handle_async_request(
File "/usr/local/lib/python3.8/site-packages/httpcore/_async/connection.py", line 99, in handle_async_request
self.socket = await self._open_socket(timeout)
File "/usr/local/lib/python3.8/site-packages/httpcore/_async/connection.py", line 130, in _open_socket
return await self.backend.open_tcp_stream(
File "/usr/local/lib/python3.8/site-packages/httpcore/_backends/auto.py", line 44, in open_tcp_stream
File "/usr/local/lib/python3.8/site-packages/httpcore/_backends/asyncio.py", line 268, in open_tcp_stream
return SocketStream(
File "/usr/local/lib/python3.8/contextlib.py", line 131, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.8/site-packages/httpcore/_exceptions.py", line 12, in map_exceptions
raise to_exc(exc) from None
httpcore.ConnectError: [Errno 111] Connect call failed ('192.168.0.25', 5000)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 155, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 63, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 199, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 257, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 170, in async_step_auth
return await self.async_step_profiles()
File "/usr/src/homeassistant/homeassistant/components/onvif/config_flow.py", line 203, in async_step_profiles
await device.update_xaddrs()
File "/usr/local/lib/python3.8/site-packages/onvif/client.py", line 276, in update_xaddrs
capabilities = await devicemgmt.GetCapabilities({"Category": "All"})
File "/usr/local/lib/python3.8/site-packages/zeep/proxy.py", line 64, in __call__
return await self._proxy._binding.send_async(
File "/usr/local/lib/python3.8/site-packages/zeep/wsdl/bindings/soap.py", line 156, in send_async
response = await client.transport.post_xml(
File "/usr/local/lib/python3.8/site-packages/zeep/transports.py", line 230, in post_xml
response = await self.post(address, message, headers)
File "/usr/local/lib/python3.8/site-packages/zeep/transports.py", line 215, in post
response = await self.client.post(
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1747, in post
return await self.request(
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1426, in request
response = await self.send(
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1511, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1546, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1580, in _send_handling_redirects
response = await self._send_single_request(request, timeout)
File "/usr/local/lib/python3.8/site-packages/httpx/_client.py", line 1621, in _send_single_request
) = await transport.handle_async_request(
File "/usr/local/lib/python3.8/site-packages/httpx/_transports/default.py", line 272, in handle_async_request
File "/usr/local/lib/python3.8/site-packages/httpx/_transports/default.py", line 78, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ConnectError: [Errno 111] Connect call failed ('192.168.0.25', 5000)
Any idea?
