Onvis HS2 connect to HA without Apple
how can I connect my Onvis 5-key switch HS2 to HA without Apple divices. The switch works with Thread. If I use my Android phone and scan the QR-code to install I will receive an message that the code is not correct. The setup code the the structure XXX-XX-XXX.
Hi, welcome to the HA community.
There are lots of potential hangups when adding Thread devices, so highly recommend reading the HA docs for Thread, and similarly for adding Matter devices. There are also some good guides on this forum for helpful hints and commissioning tips. After reading through all the checklists, and if things still aren’t working, you’ll have a better idea of what logs to post here for more effective help.
