Onvis Switch HS2 not triggering automations
Solved.
I used Device and not entity as the trigger.
Hi all,
New to Home Assistant but not Smart Homes. I have a HS2 which has been working great over Thread in HomeKit, however I’ve added it to HA, it shows up as you would expect and even registers the button clicks.
The Automations work great the first time but after that they are ignored but clicks continue to be seen under device.
I’ve rebooted the Rpi 5 and re installed the HS2 but the same thing happens, any ideas?
David
